Post by mellow on May 6, 2010 21:32:04 GMT 1
Hi m8. I used a genuine gasket on mine and even after the final torque down after running it had a TINY seep of coolant from between the barrels so i took head back off and put a tiny smear of sealer on both sides.Problem sorted ;D
Post by Norbo on May 6, 2010 22:52:03 GMT 1
I've never had a problem with patten gaskets . but i only fit the good ones not the goldwing crap and the like . But i allways put a little clear instant on both sides . and i would even with gan yam one as well .
Post by ianboom on May 10, 2010 19:13:55 GMT 1
If it's any help, i bolt the barrels on finger tight, tighten the head to the barrels (genuine gasket) and then bolt the barrels to the cases (assuming it's a YPVS). Never had a leak yet! Ian.
Post by midlifecrisisrd on May 10, 2010 21:09:10 GMT 1
If it's any help, i bolt the barrels on finger tight, tighten the head to the barrels (genuine gasket) and then bolt the barrels to the cases (assuming it's a YPVS). Never had a leak yet! Ian. I'll second that method, had a motor once that refused to seal untill it was done this way. Have done my latest with a set of norbos quality gaskets and used the NK offset torque wrench tool to tighten the base bolts then torqued the head. Not fired it up so will have to wait to find out if it worked. Steve.
Post by pepsisteve on May 11, 2010 11:36:08 GMT 1
i use versa pattern gaskets on the rd and my rgv and have not had a problem.
chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on May 16, 2010 8:21:31 GMT 1
IMO fitting either a pattern head gasket or a pattern throttle cable to your moneypit rebuild is false economy BIN THERE DUN THAT
Post by wiggy on May 16, 2010 8:34:31 GMT 1
IMO fitting either a pattern head gasket or a pattern throttle cable to your moneypit rebuild is false economy BIN THERE DUN THAT i ll second that i like your avvy btw
herb
The older I get, the faster I was!
Post by herb on May 16, 2010 9:10:36 GMT 1
I have built a lot of engines over the years and so long as you ensure the jointing face of the cylinder and the cylinder head are flat, (I use grinding paste on a surface plate or if they're really bad a little skim with the mill). Then decent pattern head gaskets, (NP or Vesrah), are perfect for the job I've never had one leak yet. You should never have to use a jointing compound with any gasket A smear of grease on most gaskets is adequate, but LC, (4LO/4L1), head gaskets should be fitted dry Yam gaskets are good but they aren't a must have at all costs ps: Always remember! After initial torque down, warm the engine and torque down again. I hope this helps as standard head gaskets can be ridiculous prices, (depending where you buy them).
dbgr
Post by dbgr on May 16, 2010 16:52:23 GMT 1
Theres no definate answer to this is there! I asked a while ago and though I havent fitted the head yet Im going for smear of oil on base gaskets and dry genuine head gasket very soon, I hope.....
herb
Post by herb on May 16, 2010 20:41:58 GMT 1
Like you say, there's no definitive answer The only thing you can say for sure is, correct preparation is everything. No matter which gaskets you choose, if the surfaces aren't perfectly flat, the joint will fail
