Post by ferret79 on May 4, 2010 23:53:25 GMT 1
im trying to get a yamaha tzr250 2ma running correctly, i have it running now but it's not ticking over great and only seems to be running on 2 cylinders when it feels like it. the bike has stood for quite a while, and the carbs were full of stale fuel and lots if crap, i spent a good afternoon cleaning carbs jets etc, and when put back together, clean fresh fuel in tank. it would only run if i kept the revs over 5k. anything below it would die. checked & cleaned plugs, replaced and tried agian, slightly better. got it ticking over but very hit and miss, left hand cylinder seems to be running alot colder than the right cylinder, left exhaust is not getting as hot as the right, any help would be great to get this bike running correctly. also what is the best way to balance the carbs correctly to get them both in sync with each other, carbs are a pair of tm28ss flat slides. greatful for any help you can give cheers
Post by mellow on May 5, 2010 17:24:07 GMT 1
Post by ferret79 on May 5, 2010 19:04:53 GMT 1
great link thanks ;D
