Post by Oliver31 on Apr 29, 2010 7:12:32 GMT 1
My rd350lc spec is as follows: Mick Abbey Race tune, std airbox at present with a pipercross airfilter,stock carbs,v force reeds,lomas pipes,nk racing booster bottle and skimmed head.
Questions guys please what is the best set up for the airbox lid off,lid on,snorkel out what does the snorkel do and as I want to get more drive lower down and put put a slightly larger rear sprocket has anyone fitted a Zeeltronic and will I notice any difference.
If any of you guys can advice I would appreciate this
Post by johnlc on Apr 29, 2010 7:24:48 GMT 1
I would fit a set of kr1s carbs as well as the zeeltronic .I find the Zeeltronic once set up makes a big difference so would definately go for it ,have it fitted myself ,well worth the money
Post by Oliver31 on Apr 29, 2010 7:53:34 GMT 1
thamks for the info,could you forward on your spec for the zeelatronic ,did you notice more pull from lower down the rev range
Post by Norbo on Apr 29, 2010 8:46:50 GMT 1
You will notice more low down more mid and more top with a zell they give more poer all round. I am developing a performance Stator and trick fly wheel with a place as well at the moment to work with the Zell kits and a standard motor . so with that fitted as wel when they are done you will get even more .
Post by johnlc on Apr 29, 2010 21:43:52 GMT 1
thamks for the info,could you forward on your spec for the zeelatronic ,did you notice more pull from lower down the rev range I definately noticed a big difference up to the band ,i need to plug the programmer into the zeel tomorrow to get you my settings ,personally i would go for the separate zeel boxes rather than the 2 in 1 set up purely because you can store 10 curves in the separate opposed to just the 2 for the 2 in 1
Post by Oliver31 on Apr 29, 2010 22:29:18 GMT 1
Thanks John where did you get your zeeltronic from,how much and it would be great if you can get the settings.
Post by johnlc on Apr 29, 2010 22:38:49 GMT 1
I got mine direct from Borut for 225 euros but think Norbo does them now
Post by johnlc on Apr 30, 2010 17:04:26 GMT 1
My settings for Zeeltronic are 500rpm 12 degrees 2000rpm 17 degrees 3000rpm 26 degrees 4500rpm 20 degrees 7000 rpm 17 degrees 9500rpm 11 degrees 10000rpm 5 degrees 10500rpm 0 degrees Any questions feel free to ask
Post by Oliver31 on Apr 30, 2010 18:49:38 GMT 1
John thanks for the settings Ill get hold of one now and give it a go.
Post by johnlc on Apr 30, 2010 19:12:07 GMT 1
Nearest dyno is a 100 miles away from me so had to use my butt cheeks ,topend is fahron tuned,reedblocks and rubbers opened out by taymar ,boyesen ds reeds ,pwk's and dynacoil
Post by johnlc on Apr 30, 2010 20:41:15 GMT 1
I would love to do a power run just to see ,how about a dyno day way up north lol
Post by Norbo on May 2, 2010 9:56:59 GMT 1
They are listed on the site mate on the trick bits page .
