vensac
Post by vensac on Apr 24, 2010 13:48:45 GMT 1
Hope this works and you see the pic,s Attachments:
vensac
Post by vensac on Apr 24, 2010 13:49:54 GMT 1
and the full bike Attachments:
vensac
Post by vensac on Apr 24, 2010 14:41:41 GMT 1
Just taken her out for the first run. The bike has been well put together brakes, suspension , etc. The problem seems to be the carbs I think. It ticks over about 3000rpm when hot, only 1200 when cool. When it comes into the power band its still a bit flat. It goes but is a bit slow. I have no idea how to setup the carbs, its been 25years! Ok I am old! It is running K+n filters not sure what the jetting should be. How do you balance the carbs???
Please help if poss
Post by mellow on Apr 24, 2010 15:17:30 GMT 1
vensac
Post by vensac on Apr 24, 2010 15:29:52 GMT 1
Thanks for your help. Do you know what jets it should be running ?? Its got allspeeds and K+n's
Post by scott on Apr 24, 2010 22:21:18 GMT 1
i would go back to std airbox for a start m8
Post by bubba on Apr 25, 2010 9:19:26 GMT 1
hope you get it sorted vensac! keep us posted on your progress with the carbs, lovely looking lc by the way!!!
Post by Norbo on Apr 25, 2010 9:25:31 GMT 1
Id have a look at what jets are in just now and the clip position on the needle and let us know what its set at now. But i allso tend to agree that if its not tuned up then a standard Air box is best .
vensac
Post by vensac on Apr 25, 2010 12:37:32 GMT 1
Ok Thanks all. Will take the carbs off it and tell you the set-up. Can put the standard airbox back on, as he gave me this with the bike, would like to keep the allspeeds on.. Although he also gave me a set of standard pipes aswell. Will it run better with these on. The mid range on the bike is good, its the top end stuff i think is flat. Give it a fist in first and it doesnt pick the front end up. I had several RD400's I am sure they were faster. Or is it just my memory and the exup, bandit 12, ducati 900, rsvr, 955 daytona and gsxr750k4 that have gone in between. ??
Post by bare on Apr 25, 2010 17:44:12 GMT 1
as above : re install the stock airbox as it will pull more strongly with it.. also ease the jetting burden. IF keen, your cyl head looks to have a thick gasket in there. If possible, do try and reset the things' "squish" to 0.9mm. It will make noticeable improvement. A reasonable assumption that you have gotten used to more advanced machinery over the years. But with a bit of coaxing this bike should still be moderately entertaining.
vensac
Post by vensac on Apr 28, 2010 13:25:26 GMT 1
passed it MOT today. Will try to strip the carbs at the weekend
vensac
Post by vensac on May 1, 2010 14:49:52 GMT 1
Have just stripped the carbs. The Slides have got blck overspray on them. The jets say 310 on them . The needles have the clip on the bottom groove. The carbs have got 31k on them. Can you tell me the correct settings? What are the air screw settings??? I am going to put the standard air box back on
Post by oldelsieboy on May 1, 2010 15:23:08 GMT 1
Have just stripped the carbs. The Slides have got blck overspray on them. The jets say 310 on them . The needles have the clip on the bottom groove. The carbs have got 31k on them. Can you tell me the correct settings? What are the air screw settings??? I am going to put the standard air box back on If your running standard airbox with Allspeeds (Gibsons) pipes the main jets should not require changing from standard which I think is 240. Not too sure on clip position but on a 4L0 its in the middle groove. The black on the slides is a non stick teflon coating not overspray. HTH OEB
vensac
Post by vensac on May 1, 2010 18:38:56 GMT 1
so 310 is far too big then? What are the standard 31k settings??
Post by oldelsieboy on May 1, 2010 21:06:04 GMT 1
so 310 is far too big then? What are the standard 31k settings?? Can you read French? I think it states, Main Jet 240 Air Jet 0.7 Jet Needle 5K1 Circlip Position 4 (from top) Pilot Jet 22.5 Air Screw 1¼ Out HTH OEB
Post by scott on May 1, 2010 21:30:56 GMT 1
i'm running a pv lump in my lc with large can allspeeds and 31k carbs and it's all set up as above execpt for needle clip poistion which is either 1 from top or 1 from bottom,sorry i can't be more spot on but it's been a while since i set it up,just try either 1 and you'll soon tell the difference,and barrels are std with no tuning.
vensac
Post by vensac on May 2, 2010 0:58:30 GMT 1
Can you read French? I think it states, Main Jet 240 Air Jet 0.7 Jet Needle 5K1 Circlip Position 4 (from top) Pilot Jet 22.5 Air Screw 1¼ Out HTH OEB Oui, je peu parle francaise. Merci a vous
Post by oldelsieboy on May 2, 2010 8:25:11 GMT 1
If your running standard airbox with Allspeeds (Gibsons) pipes the main jets should not require changing from standard which I think is 240. Not too sure on clip position but on a 4L0 its in the middle groove. The black on the slides is a non stick teflon coating not overspray. HTH OEB i have gen old school big can allspeeds on my ypvs and ran 250's to air on the side of caution as my history with 2 strokes is messy lol and still managed to melt both piston crowns due to running lean, i am running 260's in mine also on premix (not taking any chances this time) and she is almost spot on by the plug chop, so if your going to run 240's plug chop early just to cover your ass as you dont want it letting go when your 50 odd miles from home on the motorway like i was lol.... jazz When running premix you should always upjet to allow for the oil & petrol to pass the jet OEB
vensac
Post by vensac on May 10, 2010 10:26:22 GMT 1
Think mine looks a bit better than that.
