Post by midlifecrisisrd on May 25, 2010 9:21:52 GMT 1
NK racing conversion kit.
Post by midlifecrisisrd on May 25, 2010 9:25:07 GMT 1
Next step will be to get it up on it's wheels and get the motor in.
Post by midlifecrisisrd on May 25, 2010 16:59:21 GMT 1
This will make you laugh, this is what this project started as.
Post by midlifecrisisrd on Aug 18, 2010 9:42:24 GMT 1
Hi, bit of an update, lost some pics in the recent crash. Progress slow but got a set of mint microns from lcowner, finally got them fitted. Had to make rear brackets as they were from an LC and had to bend out the frame brackets to make them clear the swing arm. Think I now have all parts to finish, bodywork all painted and ready so should make good progress now. Sold a load of LC2 bits I had lying around to fund the rest. Will eventually fit NK cans once I've made stingers for them but got loads to do before that.
Post by lcowner on Aug 19, 2010 15:11:45 GMT 1
glad to c u got pipes to fit,looks well m8.only thing id like to c is the ypvs pollished on the barrells.its gunna be a nice bike... cheers paul
Post by bubba on Aug 19, 2010 18:31:56 GMT 1
that looks well nice! what colours are you going with it? looks like it had a hard life on the before photo ;D
Post by Norbo on Aug 20, 2010 8:10:10 GMT 1
Its looking smart now , you even put smoke coming out the chimdy out of the house in the frame . well thats what my little lad just said anyway
Post by midlifecrisisrd on Aug 20, 2010 8:55:52 GMT 1
glad to c u got pipes to fit,looks well m8.only thing id like to c is the ypvs pollished on the barrells.its gunna be a nice bike... cheers paul Thanks, not decided whether to polish the YPVS or not, might do something to match the paint. Funny thing is if you look at the before photo you can see the NOS head that was on it. Whoops. Steve.
Post by midlifecrisisrd on Aug 20, 2010 9:14:25 GMT 1
that looks well nice! what colours are you going with it? looks like it had a hard life on the before photo ;D Very hard life, 64000 miles, one owner though, used for commuting. Strange thing was that although it looked awful all the service parts were perfect and motor was rebuilt. Paintwork done in red and white 3 block over black as an N2 should be. Decals from Norbo - cheers. Got carbs and oil lines on now, switchgear painted yesterday and doing decals right now. Steve.
Post by Deleted on Aug 21, 2010 10:02:57 GMT 1
It just keeps getting better and better.
Post by midlifecrisisrd on Aug 31, 2010 9:40:59 GMT 1
Few more bits done, switchgear finished. Made up clocks ( getting good at that ) used TZR clocks with 150mph speedo, top cover p/coated and R clock loom fitted. Also got rad on and plumbed up. Next job is to get the electrics on and fit the fuel tap repair kit and see if it runs. Steve.
Post by midlifecrisisrd on Sept 17, 2010 16:06:53 GMT 1
Back tracked a bit, although the microns looked good I have decided to go the full hog with the wolf in sheeps clothing. Just got a set of kenny's "abbey" race pipes, need to chonge the side stand to a spring on the outside for clearance, will put up pic once done and cans on. Will need to save dosh for an open CDI from Norbo so it will rev higher (pipes peak at 10500) and eventually will get an abbey tune on my spare barrells as well as the head reprofiled/skimmed and o ringed. Steve.
Post by midlifecrisisrd on Sept 27, 2010 20:08:57 GMT 1
Got a few jobs done, moved side stand spring to outside for better clearance with the fat pipes. And finally finished rebuilding the brakes, all calipers stripped and acid dipped, then painted in PJ1 and baked in the oven. New seals and all bolts. Got a renthal sprocket, just waiting for the carrier bearing so I can fit the back wheel, caliper and brake arm before getting the pipes on. Steve
Post by scott on Sept 27, 2010 21:45:05 GMT 1
nice work on the calipers m8 8-)whats the rear caliper off m8.looks like 1 i've had with a bike and don't know what it's off
Post by midlifecrisisrd on Sept 28, 2010 7:54:03 GMT 1
nice work on the calipers m8 8-)whats the rear caliper off m8.looks like 1 i've had with a bike and don't know what it's off 1990 rgv 250 (vj21) hangs below with a torque arm. Steve.
Post by scott on Sept 28, 2010 9:19:52 GMT 1
nice work on the calipers m8 8-)whats the rear caliper off m8.looks like 1 i've had with a bike and don't know what it's off 1990 rgv 250 (vj21) hangs below with a torque arm. Steve. cheers steve,looks close to the 1 i have so i can get it sold now,thanks ;)have some karma
Post by midlifecrisisrd on Oct 3, 2010 18:27:34 GMT 1
Electric gremlins now all sorted, new fuse box fitted, 4 new indicators and a new tail light lens. Fitted the brake caliper and torque arm as well as fitting new sprocket and carrier bearing. Had some trouble fitting the pipes, left one fine as I had moved the side stand spring but RH one fouling. Knew you could not have a centre stand with them but they fouled where the bottom bolt on the NK kit fitted so had to "modify" rear of pipe with a ball hammer only to find the brake torque arm fouled too so rubber mallet time. They sound absolutely awesome, lovely ring-ting. Suppose I better get some brakes working next. Steve.
Post by billy on Oct 5, 2010 2:16:42 GMT 1
ive this problem atm apart from i feel like im 10 back now gotta have conrod big end kit done If you need a hand...... You can't use a hand as a conrod, a hand won't be able to withstand those kind of forces.
Post by lcowner on Oct 5, 2010 9:33:50 GMT 1
they are sexy lookin pipes.........
Post by midlifecrisisrd on Oct 27, 2010 14:30:27 GMT 1
Finally got the brakes on and working, nightmare bleeding them. Rad guard fitted including the rare rad hose cover and LH corner. Switgear all done and N1 Clutch lever and clamp, master cylinder and resouvoir from an Suzuki SV, exact same Nssin as RGV but without the price tag. Also finished electrics, new fuse box fitted and the old 4CE Cdi replaced with an unrestricted Zeel cdi from norbo. Really just need to get the bodywork on and see how it goes, pity the weather is crap and they have already gritted the roads up here. Steve
Post by nikfubar on Oct 27, 2010 16:20:12 GMT 1
Very nice Where are the zeels on Norbos site, cant find them
Post by midlifecrisisrd on Oct 27, 2010 17:41:29 GMT 1
Very nice Where are the zeels on Norbos site, cant find them Cheers, Zeels are in the YPVS section in the trick bits page. The cdi I have is not on there, they were made for norbo pre programmed with a decent map so you don't need all theother bits or the set up hassles. Steve
Post by midlifecrisisrd on Oct 28, 2010 12:48:45 GMT 1
Post by seanrd on Oct 28, 2010 16:29:30 GMT 1
Thats fooking lurrrvly, engine looks brilliant with all the black
Post by thepetros67 on Oct 28, 2010 16:50:24 GMT 1
Really nice bike !!! good work. Really dig the color and naked look. I observed you grinded off fairing tabs fm frame.
Petros
Post by vin on Oct 28, 2010 20:03:20 GMT 1
Sweet looking bike mate full credit to you
Post by JonW on Oct 29, 2010 0:15:23 GMT 1
Very nice indeed, good neat fitting of the parts make it look factory etc.
I thought that Kenny's exhausts could be fitted with the centre stand in place, maybe i misread that but i was sure of it... hmm...
Post by lcowner on Oct 29, 2010 0:39:21 GMT 1
coming along nicely steve
Post by midlifecrisisrd on Oct 29, 2010 8:59:43 GMT 1
Very nice indeed, good neat fitting of the parts make it look factory etc. I thought that Kenny's exhausts could be fitted with the centre stand in place, maybe i misread that but i was sure of it... hmm... Thanks for the comments guys, really pleased with it myself. You got me wondering about the stand now, can't fit one anway cause of the NK swingarm kit but you might be right. The stand bolts are slimmer than the M10 not and bolt but they have no stand stop on them for the bung but may well sit fine against the pipe. mmmm, got me thinking now, other hybrid has centre stand which is why I never got a set for it, and a tuned motor. Steve
Post by JonW on Oct 29, 2010 14:10:29 GMT 1
Sorry to give you cause for doubt... maybe drop Kenny an email but im sure i read it would fit. I planned to fit one on my 57V with the same pipes if i can make it fit. Tho i may have to move the spring as you did (can you detail how you did that by the way?)
I will also want to fit a center stand to my LC with pipes so that may get interesting depending on which engine goes in there and which pipes... hmm...
