Post by midlifecrisisrd on Apr 7, 2010 23:31:58 GMT 1
Been a roller coaster day, Called gibsons to enquire about small cans for my YPVS hybrid, lucky day, will have a set ready for the end of the week - total fluke. Got a seat from ebay, couple of small nicks in cover but a very usable seat it said. The truth - both corners burst, 20 mm rip on back edge, 30mm rip in middle and about 10 stab holes - not happy. Took R frame to mates to get lock stops and various brackets welded on - all for 6 Newcastle brown ales. Then stripped the Vj21 swing arm of the frame for latest hybrid to find a 30mm crack on rh side at swing arm pivot. Can it get any worse? Away now to book forks into philpots for rechroming, more money Let's hope that's the end of the problems. Steve
monkfish
NaNaNaNaNaNaNa Argos
Post by monkfish on Apr 8, 2010 1:08:49 GMT 1
I feel your pain bro, I recently bought a 350LC with the idea of a quick look round, service and on the road but its turnin into a minor restoration . Just think of it as a problem solving exercise and when you get it done you will wonder what all the fuss was about
Post by Norbo on Apr 8, 2010 8:43:05 GMT 1
Are you going to send the seat back .?
Post by midlifecrisisrd on Apr 8, 2010 9:03:52 GMT 1
Are you going to send the seat back .? Not sure, £29 including postage. Knew it was used but not sh*gged. Intended to use it until I eventually got it re covered but no good for that, would have bought a really cheap one if I was going to cover it straight away. Was in no mood to be rational about it yesterday so didn't contact seller. What do you think? Steve.
Post by carlos on Apr 8, 2010 18:11:19 GMT 1
Take some pics of the seat and put them up along with the description from ebay and we'll give you some honest opinions!
grunt
Post by grunt on Apr 8, 2010 19:26:41 GMT 1
ive this problem atm apart from i feel like im 10 back now gotta have conrod big end kit done
Post by carlos on Apr 8, 2010 19:44:37 GMT 1
ive this problem atm apart from i feel like im 10 back now gotta have conrod big end kit done If you need a hand......
grunt
Post by grunt on Apr 8, 2010 20:24:21 GMT 1
thanks carlos ive got someone to do the conrod ect it'l take him few days just got to get the crankshaft out of this one bearing nearly there thou got my best friend (haynes manual)
grunt
Post by grunt on Apr 8, 2010 21:48:54 GMT 1
I think with any build you seem to have to put up with some shite and get the odd dodgy part and i had my fair share but it will all come together and these hassles melt into the background sounds good to me now just to shut the neighbours up about the noise complaints and tvs freezing ;D
monkfish
Post by monkfish on Apr 8, 2010 22:21:00 GMT 1
Neighbors are so unnecessary . Does anyone own a street we could all move into
Post by midlifecrisisrd on Apr 8, 2010 22:26:20 GMT 1
I think with any build you seem to have to put up with some shite and get the odd dodgy part and i had my fair share but it will all come together and these hassles melt into the background Know what you mean, last one was the same amd it didn't put me off. Frame, clock bracket and face along with grab rail dropped off at powder coaters to day £80 the lot. Going for satin black as pipes will be satin and engine already done in it. Also got fork lowers and top yoke vapour blasted. Only neg today was the mirrors for the LC2 hybrid turned up today and they were the wrong ones so need to send them back to exchange. Now need to decide whether to get swing arm welded or try and pick up another one. Steve.
maxman
Post by maxman on Apr 9, 2010 20:45:55 GMT 1
Is it a 31k seat you need? I have a mint one!!!in black for sale???
Post by midlifecrisisrd on Apr 11, 2010 13:32:53 GMT 1
Is it a 31k seat you need? I have a mint one!!!in black for sale??? Unfortunately not, it is an F2 one. Will just get the duff one recovered. Just annoying as I had the chance of a perfect one for £50. Steve.
Post by midlifecrisisrd on Apr 11, 2010 13:38:52 GMT 1
Cracked swingarm sorted, just won one off ebay for 99p, just needs a hugger mount sorting.
Had the LC2/VJ22 out for it's maiden voyage yesterday, only did 5 miles to petrol station and back as a shake down. Only slight problem was the rear banjo bolt still clashes with the swing arm, even made it loosen the bolt so leaked brake fluid but luckily not onto any painted bits. Running in so can't rev it but either the speedo is out or the bigger rear sprocket is a bit too much. 5000rpm in top is 50mph, doesn't half feel nippy though. Think I have a sticking caliper as well so off to check now. Steve.
Post by midlifecrisisrd on Apr 14, 2010 23:13:26 GMT 1
Frame and brackets back from powder coater today, looks mean in satin. Changed mind about pipes and went for chrome so 4 week delay but forks picked up and away. Also my 99p swing arm turned up, well tidy.
Will have to upgrade photobucket account and start some photos.
Steve.
Post by nikfubar on Apr 15, 2010 9:02:25 GMT 1
Post by looey on Apr 15, 2010 9:11:10 GMT 1
Post by midlifecrisisrd on Apr 15, 2010 12:43:36 GMT 1
Cheers for the seat cover tips, will look into them. Now got 4 x washers behind master cylinder and a ss bolt, just clears. Hvae milles bit where it hit so just needs polished up and it will look ok. Heading out to garage to see how NK swing arm conversion kit fits. Steve.
Post by midlifecrisisrd on Apr 27, 2010 9:53:25 GMT 1
NK kit now fitted, easy once you work out which way everything goes and bite the bullet and grind the frame at the correct side. Nice bit of kit.
Fork legs, top and bottom yoke painted up and ready, just waiting for the stanchions to come back from philpots.
Got some nice SS fine pitch bolts for the hanger mounts and tie bars - pricey
Had to get a new bush for swing arm as one was missing from ebay one and the other arms bushes were knacked. Just losing the feeling in my fingers trying to polish the swing arm a bit.
Think I've got every thing now, just needs cleaned up/painted and assembled before the costly bit of paint.
Steve.
Post by nikfubar on Apr 27, 2010 11:33:06 GMT 1
Where did you get fine pitch SS bolts, I get all my fixings from here www.stagonset.co.uk/ but they don't do fine pitch.
Post by midlifecrisisrd on Apr 27, 2010 16:20:13 GMT 1
Where did you get fine pitch SS bolts, I get all my fixings from here www.stagonset.co.uk/ but they don't do fine pitch. Usually get mine from there too. Got them off good old ebay, just search M10 x 1.25 and you'll get loads, not as cheap as stagonset but cheaper than the Yam ones. Steve.
Post by mellow on Apr 27, 2010 17:05:58 GMT 1
try inox fasteners
Post by midlifecrisisrd on Apr 28, 2010 8:10:43 GMT 1
try inox fasteners That's who I got them from off ebay Steve.
Post by mellow on Apr 28, 2010 20:14:00 GMT 1
oh lol.nice bloke john is ;D
Post by soad1110 on May 6, 2010 22:07:53 GMT 1
nice
Post by midlifecrisisrd on May 11, 2010 19:14:41 GMT 1
Not moving fast, still not got forks back, in the 5th week now, not happy, said it would be 2. Only the second time i've had it done, first time took weeks as well and they never stopped weeping, better not happen this time. Kicking myself as was nearly the same price for new ones from All Bike Engineering.
Lower linkage bearings shot so had to get another one. Going out now to fit the swingarm and the yokes.
Steve.
Post by carlos on May 11, 2010 19:36:06 GMT 1
Good luck
chorltoncumrd
I need to ship up or shape out
Post by chorltoncumrd on May 14, 2010 14:40:29 GMT 1
midlifecrisisrd wrote Been a roller coaster day, Called gibsons to enquire about small cans for my YPVS hybrid, lucky day, will have a set ready for the end of the week - total fluke. Got a seat from ebay, couple of small nicks in cover but a very usable seat it said. The truth - both corners burst, 20 mm rip on back edge, 30mm rip in middle and about 10 stab holes - not happy. Took R frame to mates to get lock stops and various brackets welded on - all for 6 Newcastle brown ales. Then stripped the Vj21 swing arm of the frame for latest hybrid to find a 30mm crack on rh side at swing arm pivot. Can it get any worse? Albert King wrote this for you sing along Born under a bad sign I been down since I begin to crawl If it wasn't for bad luck, I wouldn't have no luck at all
Post by midlifecrisisrd on May 21, 2010 16:07:02 GMT 1
Hopefully bad luck bit over, allspeeds came yesterday, decided to put them on my other bike, will put the converted F2's on this one to keep in with the looks standard at first glance idea.
Fork stanchions back from Phillpot's, thank god. Time for some building and some pics I think.
Steve.
Post by midlifecrisisrd on May 25, 2010 9:17:27 GMT 1
A few steps forward. Forks built and fitted, swing arm on.
Frame in Matt Black, Was an R so all fairing brackets removed, rad mounts removed and new one fitted for N2 Guard. Didn't have mounts for frame infills so made new ones. Removed old sterring lock bracket from head stock along with fairing mount and welded on bracket to suit new steering lock. Instead of removing steering stops from ypkes and re welding them simply welded new stops on frame at rear of head at gusset. Left origional lug on frame in case of changes. Sorry for crap images, camera would not focus properly and was in hurry.
