broony
Post by broony on Nov 29, 2024 23:14:38 GMT 1
just started my build so probably going to be on here constantly looking for info and help! lc with rgv upside down front end and banana swing arm , ypvs engine will be the basics. first question is what size rear sprocket have most of you used with this set up ? Tia
LC RGV
Nov 29, 2024 23:26:12 GMT 1
Post by JonW on Nov 29, 2024 23:26:12 GMT 1
Many of us have done these builds over the years so there are lots of build threads on here with info in them which is worth reading when you have time, xmas/boxing days...  I have 38 and 39, but depends on the front and what you are trying to achieve. Any pics of your build's raw materials?
broony
LC RGV
Nov 29, 2024 23:39:34 GMT 1
JonW likes this
Post by broony on Nov 29, 2024 23:39:34 GMT 1
ill get some pics up asap. just had frame powder coated , wheels done and dropped of at a mates to get the new tyres and bearings done. swing aram came back from NK with the mod so thats ready for a good old polish. new discs ordered and calipers are next to get stripped and rebuilt . Ive had the RGV bits lying for over 10 years and have loads of LC parts but now that ive started its the small bits that you realise are missing that give you the biggest headache , right now its spacers etc from the wheel spindles, some are missing and finding it difficult to find them. 350 ypvs engine all rebuilt and sitting ready to drop in .
Had an LC brand new on my 17th birthday in '82' ! Mars bar with red frame and gold wheels . going for the same look albiet with the mods. another mid life crisis to add to the list !hahaha
LC RGV
Nov 30, 2024 0:01:50 GMT 1
via mobile
JonW likes this
Post by midlifecrisisrd on Nov 30, 2024 0:01:50 GMT 1
As Jonw says 17/39 is prob best
May have difficulty with the rear as B&C express don't cut specials from Renthal blanks anymore
I've got a 41t on just now and it's a bit too low geared
LC RGV
Nov 30, 2024 0:02:22 GMT 1
via mobile
JonW likes this
Post by midlifecrisisrd on Nov 30, 2024 0:02:22 GMT 1
Oh and you get alloy wheel spacer kits from Tyga or the tuning works
LC RGV
Nov 30, 2024 2:10:51 GMT 1
via mobile
Post by badger1 on Nov 30, 2024 2:10:51 GMT 1
broony
LC RGV
Dec 1, 2024 17:19:39 GMT 1
Post by broony on Dec 1, 2024 17:19:39 GMT 1
what bars has everyone fitted ? quite like the idea of Renthal flat bars but not sure
LC RGV
Dec 1, 2024 17:25:45 GMT 1
Post by stusco on Dec 1, 2024 17:25:45 GMT 1
Ive got them on a standard front end i think they look great
Post by stusco on Dec 1, 2024 17:27:45 GMT 1
broony
LC RGV
Dec 1, 2024 18:03:28 GMT 1
Post by broony on Dec 1, 2024 18:03:28 GMT 1
very nice . love it
LC RGV
Dec 1, 2024 23:03:14 GMT 1
Post by JonW on Dec 1, 2024 23:03:14 GMT 1
MX bars, but 758 bars work best.
Post by donkeychomp on Dec 1, 2024 23:13:54 GMT 1
Pfft. Clip ons surely.
broony
LC RGV
Dec 2, 2024 9:23:36 GMT 1
Post by broony on Dec 2, 2024 9:23:36 GMT 1
At my age straight bars are becoming a requirement. Rebuilt my old ZX9R this year , took it out for 160 mile blast (great at the time) woke up the next morning to find i couldnt move my neck for 3 days !hahahahaha
broony
LC RGV
Dec 2, 2024 21:01:40 GMT 1
Post by broony on Dec 2, 2024 21:01:40 GMT 1
The RGV fork legs were in a bit of a state so had them vapour blasted when rebuilding them with new seals etc . I quite like the matt look after the vapour blast , has anyone left them like this? what have you coated them with to keep them clean and add some protection? Thanks
LC RGV
Dec 2, 2024 21:06:10 GMT 1
Post by stusco on Dec 2, 2024 21:06:10 GMT 1
Most people rub around them with red scotch brite for the standard look after vapour blast and maintain with acf50 you can polish first for a shinier if thats a word finish
Post by 1966baz on Dec 3, 2024 17:24:30 GMT 1
This is my one, nearly done now.Really excellent bikes.
broony
LC RGV
Dec 3, 2024 20:33:03 GMT 1
Post by broony on Dec 3, 2024 20:33:03 GMT 1
nice
broony
LC RGV
Dec 3, 2024 20:37:14 GMT 1
Post by broony on Dec 3, 2024 20:37:14 GMT 1
very nice
broony
LC RGV
Dec 3, 2024 20:37:52 GMT 1
Post by broony on Dec 3, 2024 20:37:52 GMT 1
what headlight brackets did you use on the RGV forks ?
Post by 1966baz on Dec 4, 2024 13:18:29 GMT 1
They are off ebay.50mm I think.
broony
LC RGV
Dec 10, 2024 20:53:21 GMT 1
Post by broony on Dec 10, 2024 20:53:21 GMT 1
First problem , turns out that i have the RGV banana arm but a GSXR 400 rear wheel ! I had a look on Fowlers website at he parts drawings and although the swing arm is different , the rear wheel and spacers etc looks almost identical with the exception of the sprocket carrier which is how i found out when i ordered a sprocket for the RGV and found it was nothing like the one i have. Anyone know if its possible to use this wheel etc with the banana arm? HELP ?
LC RGV
Dec 10, 2024 21:14:13 GMT 1
via mobile
Post by midlifecrisisrd on Dec 10, 2024 21:14:13 GMT 1
Hi
The 400 wheel will go in as spindle and spacers etc are the same dimensions
Sprocket wise use a Suzuki gs500 sprocket. You may need to machine 5mm off the carrier face or use a gsf400 carrier
Problem is the disc is 5mm nearer the arm so you will need a custom caliper bracket as the RGV one won't work
I have this set up
Or get an rgv wheel which is rare/spendy
Post by midlifecrisisrd on Dec 10, 2024 21:18:00 GMT 1
Pics so it happened 🤣 This is an LC I did but have the same on my 31k with rgv arm
broony
LC RGV
Dec 10, 2024 21:20:20 GMT 1
Post by broony on Dec 10, 2024 21:20:20 GMT 1
Does the GSF 400 carrier fit straight onto the wheel and solve the problem with the sprocket ? ie no need to machine the 5mm off ? If so would it all fit with my wheel and banana arm and just leave the caliper bracket issue to solve ? Thanks
LC RGV
Dec 10, 2024 23:07:30 GMT 1
via mobile
Post by midlifecrisisrd on Dec 10, 2024 23:07:30 GMT 1
The gk76 400, gsf400 and GS500 carrier are all identical other than offset but from memory the GS doesn't have enough offset as ran a 130 tyre on a 3.5 rim
Gsf 400 is the best but you will have to use the gk76 bearing and inner spacer as the bandit was a 17mm spindle
The thing is as many have found when doing the rgv conversion is that sometimes the offset is slightly different
The good thing about the gs500 steel sprocket is that the teeth are slightly offset with the face so mounting it back to front will reduce the offset another 2mm
It would just leave the caliper bracket to sort
Post by midlifecrisisrd on Dec 10, 2024 23:11:26 GMT 1
Hers some pics of my 31k/rgv set up Fabricated from 10mm plate then 2 spacers made to centralise it
LC RGV
Dec 11, 2024 2:24:55 GMT 1
Post by JonW on Dec 11, 2024 2:24:55 GMT 1
The random offset is a weird one, but its haunted me as well. I did wonder if something get bent and that woudld make sense... were talking LCs and RGVs... who hasnt thrown one at the scenery at some point?!
broony
LC RGV
Dec 11, 2024 7:38:28 GMT 1
Post by broony on Dec 11, 2024 7:38:28 GMT 1
Great info guys , i have had a look on ebay and found two GSF400 sprocket carriers , first is GK75A 89-91 or there is a GK7AA 95-97 ? Would it be the 89-91 GK75A id need ?
LC RGV
Dec 16, 2024 9:36:28 GMT 1
via mobile
Post by midlifecrisisrd on Dec 16, 2024 9:36:28 GMT 1
It will be the earlier one
Did they not change to straight spokes after that instead of angled
Post by lcmarky on Dec 16, 2024 10:10:40 GMT 1
Pics so it happened 🤣 This is an LC I did but have the same on my 31k with rgv arm   Blimey - That's a lovely build!
