Post by Yogi on Apr 15, 2024 14:28:31 GMT 1
Cheers Jon π
Always a hammer near by π
Post by Yogi on Apr 20, 2024 17:13:40 GMT 1
Managed with my only day off yesterday to fit the Triumph stand ![](https://live.staticflickr.com/65535/53666449251_7c55a9c004.jpg) Also welded a new lock stop on, couldnβt drill the ally yoke without losing strength ![](https://live.staticflickr.com/65535/53666449246_5ca1480ccd.jpg) Bit more tidying up and itβll be ready for powder coat Matt πΆπ»πΆ
Post by Yogi on May 8, 2024 16:59:55 GMT 1
What an absolute ball ache trying to get the outer casings for the dog bone bushes out of the swinger When i started stripping it ready for coating the inner rollers just fell out with all the rust ![](https://live.staticflickr.com/65535/53707987900_023bc9a37b_b.jpg) Thereβs virtually no lip inside to get a drift on and itβs as soft as cheese,ended up hacksawing through the pair together plenty of heat and a blind bearing puller and there out at last π± MattπΆπΆπ»
401963
![*](//storage.proboards.com/forum/images/stars/star_black.png)
Post by 401963 on May 16, 2024 20:04:55 GMT 1
Hi Yogi , i`m doing the same conversion on a f2 , just wondering if you got a picture of the rear shock mounting , where the shock goes down through the swing arm mine seems to be fouling on the spring !. yours shock seems to be more upright , if that makes sense , thanks Paul
Post by Yogi on May 17, 2024 18:30:43 GMT 1
Hi Yogi , i`m doing the same conversion on a f2 , just wondering if you got a picture of the rear shock mounting , where the shock goes down through the swing arm mine seems to be fouling on the spring !. yours shock seems to be more upright , if that makes sense , thanks Paul Hi Paul You have to move the top mount down and back to make it work ![](https://live.staticflickr.com/65535/53728260160_f6a6feb185_k.jpg) I had to grind the collars off on the inside where the shock used to mount and bolt through with spacers on the inside of the plates ![](https://live.staticflickr.com/65535/53727820261_b3af5d6574_k.jpg) I was going to weld them in but there strong enough and can be removed if needed Hope it helps π Matt πΆπ»πΆ
401963
Post by 401963 on May 17, 2024 20:29:45 GMT 1
Thanks Matt for you help , thats a great help ! , Off to the garage to make some brackets now , watching your build with interest
Post by abar121 on May 18, 2024 9:49:37 GMT 1
That bracket looks just the ticket, thanks Matt. Any measurements would be helpful, I have one to do later in the year.
Cheers.
Post by Yogi on May 18, 2024 13:58:08 GMT 1
That bracket looks just the ticket, thanks Matt. Any measurements would be helpful, I have one to do later in the year. Cheers. Remind me in a couple of weeks Al when the powder coating comes back,I only put it in yesterday π
Post by abar121 on Jun 3, 2024 19:41:00 GMT 1
Looking forward to another update now that the N1 is getting there!
If you have a moment to measure up, would be great. Cheers.
Post by Yogi on Jun 8, 2024 18:38:47 GMT 1
Looking forward to another update now that the N1 is getting there! If you have a moment to measure up, would be great. Cheers. Pm,d you
Post by Yogi on Jun 8, 2024 18:44:39 GMT 1
Back home and had a day sorting the back end ![](https://live.staticflickr.com/65535/53778092680_5c243be923_k.jpg) Matt π»πΆπΆ
Post by donkeychomp on Jun 8, 2024 21:12:07 GMT 1
I do like that. A lot.
Post by Yogi on Jun 9, 2024 9:17:46 GMT 1
I do like that. A lot. Alex Cheers Alex π
Post by Yogi on Jun 9, 2024 16:48:24 GMT 1
Dodgey pic but you get the idea π€£ ![](https://live.staticflickr.com/65535/53780050020_33323e2667_k.jpg) Matt πΆπ»πΆ
Post by donkeychomp on Jun 9, 2024 21:11:24 GMT 1
Hubba hubba.
Post by mouse on Jun 10, 2024 6:27:07 GMT 1
Looking great Matt.
Mouse
Post by Mr Kipling on Aug 8, 2024 16:10:35 GMT 1
Any updates on this.....
Post by abar121 on Aug 8, 2024 16:19:48 GMT 1
Cor, love the latest photos. I need to get my arse into gear.
Post by Yogi on Aug 8, 2024 16:39:48 GMT 1
Post by Mr Kipling on Aug 10, 2024 12:22:01 GMT 1
That looks superb mate , cant wait to see it dressed....
Post by Yogi on Aug 12, 2024 15:34:10 GMT 1
Starting to take shape with the arrival of the brakes π ![](https://live.staticflickr.com/65535/53918368501_0e977e6083_k.jpg) Matt πΆπΆπ»π»
Post by donkeychomp on Aug 12, 2024 21:18:33 GMT 1
Tasty. Love Brembos. Are you leaving it all gold or gently sanding the lettering back?
Post by Yogi on Aug 13, 2024 15:19:06 GMT 1
Tasty. Love Brembos. Are you leaving it all gold or gently sanding the lettering back? Alex I need to sand them back somehow π€
Post by jon on Aug 13, 2024 18:47:48 GMT 1
Tasty. Love Brembos. Are you leaving it all gold or gently sanding the lettering back? Alex I need to sand them back somehow π€ Knowing you like to do things properly. If I was you I would bet them milled off. The machining marks would look proper. A bit like LC wheel spokes. Also you wonβt mess it up as it will be super precise. Jon
Post by donkeychomp on Aug 13, 2024 21:47:22 GMT 1
I use a block of wood and 240 grit. But then again, I'm not very proper...
Post by badger1 on Aug 14, 2024 0:06:50 GMT 1
Rub them up and down on the concrete ππ
tippy
![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png)
Post by tippy on Aug 14, 2024 16:38:14 GMT 1
Rub them up and down on the concrete ππ In the dark, obviously.
Post by Yogi on Aug 14, 2024 20:51:34 GMT 1
Some good ideas there chaps π«£
Iβve gotta go with the concrete in the dark ππ€£
I havenβt ruled out trying to paint them π
Post by Yogi on Aug 16, 2024 16:23:05 GMT 1
Carefully filed the faces on the brembo,s ![](https://live.staticflickr.com/65535/53927264510_95d33266b9_k.jpg) ![](https://live.staticflickr.com/65535/53927169234_2393f45fbf_k.jpg) Then fitted the polished stainless pipes ![](https://live.staticflickr.com/65535/53927057003_2ccbb5badc_k.jpg) Getting closer π€ Matt π»πΆπ»πΆ
Post by donkeychomp on Aug 16, 2024 21:47:54 GMT 1
Fan-bleedin-tastic!
