brains
Post by brains on Mar 17, 2010 22:38:44 GMT 1
Hi,
I have bought an engine for my current project, but im not sure exactly what it is. Im hoping someone here who knows what to look for will be able to tell me what to look for.
The engine number is missing so no ideas from there.
The Barrels have 31K stamped on them so I know there from the the 31K the Head has YPVS on the side of it. So i think the top end is the 31k.
Is there a way of identifying the bottom half? Is it possible that its a 4l1 bottom end with 31K top end and how can I tell.
Even if this is the case, are there any problems that this would create if I was to leave it as is?
Thanks in advance
Post by oldelsieboy on Mar 17, 2010 22:46:01 GMT 1
YPVS top end will not fit 4L1 cases totally different bolt arrangement.
Post by midlifecrisisrd on Mar 18, 2010 14:38:21 GMT 1
Hi, I have bought an engine for my current project, but im not sure exactly what it is. Im hoping someone here who knows what to look for will be able to tell me what to look for. The engine number is missing so no ideas from there. The Barrels have 31K stamped on them so I know there from the the 31K the Head has YPVS on the side of it. So i think the top end is the 31k. Is there a way of identifying the bottom half? Is it possible that its a 4l1 bottom end with 31K top end and how can I tell. Even if this is the case, are there any problems that this would create if I was to leave it as is? Thanks in advance Biggest hint will be the tacho drive. If it has one ( towards rear of top case) it is probably a 31k unless someone has converted it. If it has a blank fitted it will be a 1UA or 1WT (same) and if the case has no blank that can be removed it is a 4CE (R) Hope that helps, Steve.
Post by Shytalk on May 27, 2010 12:33:46 GMT 1
Hi to all ! I am new here and for the first time having RD350YPVS 31K year 85 an old love...Does anybody can tell me what engine I have due to some misunderstanding. On barrels from both sides is casted 31K on the bootom 347cm2 and the engine number same as frame:*31K-030669*. On the aluminum tag bolted onto frame same numbers... THX a lot You have a 31K RD350 Yamaha Powervalve engine. YPVS.
Post by Shytalk on May 27, 2010 12:35:37 GMT 1
Hi, I have bought an engine for my current project, but im not sure exactly what it is. Im hoping someone here who knows what to look for will be able to tell me what to look for. The engine number is missing so no ideas from there. The Barrels have 31K stamped on them so I know there from the the 31K the Head has YPVS on the side of it. So i think the top end is the 31k. Is there a way of identifying the bottom half? Is it possible that its a 4l1 bottom end with 31K top end and how can I tell. Even if this is the case, are there any problems that this would create if I was to leave it as is? Thanks in advance Best bet is put a few pictures of it up - especially if the engine number is missing.
Post by midlifecrisisrd on May 27, 2010 15:44:48 GMT 1
Hi to all ! I am new here and for the first time having RD350YPVS 31K year 85 an old love...Does anybody can tell me what engine I have due to some misunderstanding. On barrels from both sides is casted 31K on the bootom 347cm2 and the engine number same as frame:*31K-030669*. On the aluminum tag bolted onto frame same numbers... THX a lot You have a 31K RD350 Yamaha Powervalve engine. YPVS. According to Norbo's data it is a 84 model Lc2 (31k-028101 to 31K-044000) bikini fairing and belly pan model.
Post by Shytalk on May 28, 2010 15:02:52 GMT 1
thanks a lot for prompt reply. Doubts are cleared, believe or not just yesterday I found her on advert...took lorry and did 1100 km to grab it...She is in solid condition but it is not as I want. She is going to general overhaul...probably a bit oversize...make up and enjoy ride...as well looking for RD 500 but it looks like... Mission impossible...350's are hard to find very very rare...500's only with good luck and deep pocket. Attached photo is from advert, when I start with project there will be fully reported...sure additional advices and guidances will be highy appreciated...obviously belly pan missing That's a nice enough looking bike to start with
Post by Norbo on May 28, 2010 18:32:57 GMT 1
Looks like a good bike and its got a set of Nickons on as well .
