Post by dougw on Feb 24, 2023 10:18:20 GMT 1
That's another £9.94 this forum has just cost me.
This is not helping in the saving for the Ignitec and Power Dynamo I need to get next for the long stroke YPVS build.
I`ve got to admit to have been running MandP clear 2t oil pipes connected to the Arrow rebuilt pump on my stock(ish) daily ride 4L0.
I repent and will be fitting the genuine yam lines now.
Post by arrow on Feb 24, 2023 12:34:59 GMT 1
My only reason for perhaps not running a pump on my 385 was the want to use straight cut gears. I’ve chosen to run the pump over the gears. Jon Am I being daft here or is the oil pump not driven off the other little gear on the Crank end Not the straight cut primary Water pump too Steve No Steve, only the water pump is driven off that smaller gear.
Post by midlifecrisisrd on Feb 24, 2023 14:45:24 GMT 1
Never paid any attention lol
Post by chippy348 on Feb 24, 2023 14:57:42 GMT 1
I run clear on all my bikes and past customer bikes with zero issues, the Aprilia AF1/ RS 125 comes with it from factory (pump to carb) i find it comforting to see oil in the lines before i start anything up.
The only point i will make is the stuff i use in Made in Italy and not china stuff
Post by arrow on Feb 24, 2023 15:00:55 GMT 1
I run clear on all my bikes and past customer bikes with zero issues, the Aprilia AF1/ RS 125 comes with it from factory (pump to carb) i find it comforting to see oil in the lines before i start anything up. The only point i will make is the stuff i use in Made in Italy and not china stuff Now there's a thing. Clear pipes of the correct specification is probably the best option of all.
Post by beardy on Feb 24, 2023 15:09:02 GMT 1
I run clear on all my bikes and past customer bikes with zero issues, the Aprilia AF1/ RS 125 comes with it from factory (pump to carb) i find it comforting to see oil in the lines before i start anything up. The only point i will make is the stuff i use in Made in Italy and not china stuff Do you have a link for the pipe please 👍🏻
Post by 4l04ever on Feb 24, 2023 19:15:20 GMT 1
There are multiple types of material used for clear lines, so which material was causing a problem?
I have seen PVC, Nylon, PU, latex and Tygon versions on eBay.
Post by 4l04ever on Feb 24, 2023 19:20:15 GMT 1
Post by 4l04ever on Feb 24, 2023 22:42:04 GMT 1
Hi arrowDo you know which material you have seen issues with?
Post by arrow on Feb 24, 2023 22:49:41 GMT 1
Hi arrowDo you know which material you have seen issues with? Hi Rob, no sorry. I never got to know what they were made from.
Post by 4l04ever on Feb 24, 2023 22:59:20 GMT 1
It could definitely be the wrong grade of PVC tube.
With so many to choose from and dodgy Chinese suppliers it would be easy to get unsuitable clear pipework.
This sounds likely to be the underlying issue with clear pipes. It is difficult to identify a pipe with no writing on it.
Post by 4l04ever on Feb 24, 2023 23:00:34 GMT 1
The Tygon F-4040-A is rated for fuel and oil, so should be fine. A friend is having the LC with these pipes on, so we can keep an eye on how it lasts/performs.
Post by arrow on Feb 24, 2023 23:11:40 GMT 1
This is the issue that I've been talking about. Nobody contacts me to say, guess what, I'm running clear pipes with no problems. I only get calls about the problem ones. Although I'm well aware (as previously stated) that there is decent stuff out there.
Post by arrow on Feb 24, 2023 23:21:28 GMT 1
Any feed back on here will be very useful to the other lads.
Could you just do one other thing please?
When the pump is all plumbed in, bled and been in use for a week or so, could you remove the pipes at the carb end and leave the ends in a couple of egg cups or similar for a couple of days? This will establish if the check valves are working correctly.
If they ARE passing it will mask the monitoring of the afore mentioned problems.
Thanks.
Post by Bozzy on Feb 28, 2023 13:57:01 GMT 1
Post by chrisg on Feb 28, 2023 16:07:24 GMT 1
I run clear on all my bikes and past customer bikes with zero issues, the Aprilia AF1/ RS 125 comes with it from factory (pump to carb) i find it comforting to see oil in the lines before i start anything up. The only point i will make is the stuff i use in Made in Italy and not china stuff Just to play devils advocate, if oil in the clear lines stopped flowing, you would not be able to see that it had stopped because of its low flow rate. ie. it would still look the same stopped or slow flow
Post by dougw on Feb 28, 2023 17:55:22 GMT 1
I run clear on all my bikes and past customer bikes with zero issues, the Aprilia AF1/ RS 125 comes with it from factory (pump to carb) i find it comforting to see oil in the lines before i start anything up. The only point i will make is the stuff i use in Made in Italy and not china stuff Just to play devils advocate, if oil in the clear lines stopped flowing, you would not be able to see that it had stopped because of its low flow rate. ie. it would still look the same stopped or slow flow Agreed. But, if there was no oil in the pump feed, would the pump, being positive displacement, purge the oil from the clear lines with air ? Admittedly, probably be too late by the time you noticed.
Post by keith101 on Feb 28, 2023 18:08:45 GMT 1
This thread always reminds me of the animal farm chant, just swop two legs good with black pipe and clear pipe for the 4 legs bad, and obviously nothing in between 😃
Post by beardy on Feb 28, 2023 18:55:12 GMT 1
I run clear on all my bikes and past customer bikes with zero issues, the Aprilia AF1/ RS 125 comes with it from factory (pump to carb) i find it comforting to see oil in the lines before i start anything up. The only point i will make is the stuff i use in Made in Italy and not china stuff Just to play devils advocate, if oil in the clear lines stopped flowing, you would not be able to see that it had stopped because of its low flow rate. ie. it would still look the same stopped or slow flow Unless you have bubbles. You can see them pulsate 👍🏻
Post by 4l04ever on Dec 29, 2023 12:31:28 GMT 1
Coming back to this thread, I was just looking for some clear fuel resistant pipe for my Ethanol removal kit and found this information :- www.hoseshop.net/blog/pvc-vs-polyurethane-hose-right/It looks like PU (Polyurethane) is the way to go. PVC is more gas permeable, goes hard at colder temperatures and is less resistant to petrol based chemicals.
