Post by JMW on May 25, 2022 10:07:49 GMT 1
Does anyone know if you can happily give an older non USD fork model the later front end? All I want to do is have the USD forks on an early EXUP bike to give it a better look and hopefully improve the handling….
Any pointers plz 😊
Post by Robbieben on May 25, 2022 10:12:11 GMT 1
Does anyone know if you can happily give an older non USD fork model the later front end? All I want to do is have the USD forks on an early EXUP bike to give it a better look and hopefully improve the handling…. Any pointers plz 😊 Havn't modified an EXUp but many others converted to later USD forks, sometimes its an easy swap, just different bearings and seals for the headstock, sometimes its a straight swap, othertimes you'll need to machine or change the headstock shaft to make it work, anything is possible depending on how much work, time and effort you want to put in to make it work.
