Post by vectisitch on May 18, 2022 12:37:45 GMT 1
Are TSA still around? I've sent an email but had no response as i want some other end cans. Are there any other options for 200mm carbon end cans??
Post by evochris on May 18, 2022 13:56:55 GMT 1
Post by vectisitch on May 18, 2022 14:11:22 GMT 1
Post by evochris on May 18, 2022 14:33:01 GMT 1
You can easily cut down the ally Tyga units, its 3 or 5 rivets drilled out, the tube and baffle shortened to desired length then rivet back together I have done this type of thing on many a 2 and 4 stroke exhaust.
Post by vectisitch on May 18, 2022 14:51:28 GMT 1
Thats an option but i want carbon cans really. These are exactly what i want but in 200mm
Post by stusco on May 18, 2022 15:18:01 GMT 1
Norbos are 150mm or 250mm
Post by vectisitch on May 18, 2022 15:34:24 GMT 1
Yes. I just find 250mm to be too long
Post by stevesmith on May 18, 2022 16:17:55 GMT 1
I believe Kenny is on here...
Post by stusco on May 18, 2022 16:19:25 GMT 1
Mark Dent (performance fabrications)makes cans to any spec
Post by stusco on May 18, 2022 16:20:55 GMT 1
Yes. I just find 250mm to be too long I agree i have a set of full length carbon cans and they went wobbly after 500 mile I believe it’s because they are too long
Post by 4l04ever on May 18, 2022 16:33:45 GMT 1
Yes. I just find 250mm to be too long I agree i have a set of full length carbon cans and they went wobbly after 500 mile I believe it’s because they are too long Threadlock should help
Post by vectisitch on May 18, 2022 16:41:34 GMT 1
I'm thinking of going for norbos tz style carbon or carbon keeler 250mm ones and cutting them down but don't really want to do that if there are alternatives
Post by stusco on May 18, 2022 17:13:41 GMT 1
I agree i have a set of full length carbon cans and they went wobbly after 500 mile I believe it’s because they are too long Threadlock should help It was the rivets that went slack at the three hole flange end,i reccon due to weight and vibration
Post by stusco on May 18, 2022 17:14:26 GMT 1
I'm thinking of going for norbos tz style carbon or carbon keeler 250mm ones and cutting them down but don't really want to do that if there are alternatives I have Norbos 150mm one and they sound amazing
Post by vectisitch on May 18, 2022 17:31:56 GMT 1
I'm thinking of going for norbos tz style carbon or carbon keeler 250mm ones and cutting them down but don't really want to do that if there are alternatives I have Norbos 150mm one and they sound amazing I have tsa 150mm alloy cans but I'm finding the back of my bike gets covered in sticky 2 stroke splatters. I was thinking longer cans with the tz style exit pipes might help with that
Post by bare on May 18, 2022 17:53:38 GMT 1
It could be expedient to slip on wee extender tubes to the 'cans' exh outlets.
Post by muttsnuts on May 18, 2022 19:22:01 GMT 1
I don't do carbon cans, they are too prone to cracking, breaking and coming loose - which equals lots of come backs and complaints, so I just avoid carbon cans
Post by vectisitch on May 18, 2022 19:23:54 GMT 1
Yeh after reading above I think carbon could be a problem. Still can't find 200mm cans in any material. So cutting down looks like the option
Post by midlifecrisisrd on May 18, 2022 19:25:38 GMT 1
Yeh after reading above I think carbon could be a problem. Still can't find 200mm cans in any material. So cutting down looks like the option Will Kenny not make you a set? Steve
Post by vectisitch on May 18, 2022 19:28:37 GMT 1
Yeh after reading above I think carbon could be a problem. Still can't find 200mm cans in any material. So cutting down looks like the option Will Kenny not make you a set? Steve I've not heard back from the email I sent yet. Looks like he's not been on here since March?? I really want the style of end caps as the above picture too.
Post by abar121 on May 18, 2022 19:29:20 GMT 1
Swarbrick used to do them. I had a set on my R1-Z in carbon and zero complaints.
Post by midlifecrisisrd on May 18, 2022 19:34:32 GMT 1
These are TSA cans Steve
Post by midlifecrisisrd on May 18, 2022 19:38:19 GMT 1
As has been said Dave Swarbrick will also make you specific cans Here are the ones from my TR pipes and a set he made for my 3hm1 standard pipes Steve
Post by vectisitch on May 18, 2022 19:53:11 GMT 1
These are TSA cans Steve Yep. Those are the exact cans I have. I bought them off you. Lolol
Post by muttsnuts on May 18, 2022 20:06:39 GMT 1
I can make you 200mm cans, I can make any length upto 300mm, but I don't do the angled end, mine have a flute on them, if I get chance I'll take a picture of some tomorrow, but I am mega busy at the moment, so might not get chance
Post by midlifecrisisrd on May 18, 2022 20:21:42 GMT 1
These are TSA cans Steve Yep. Those are the exact cans I have. I bought them off you. Lolol Oopsies, forgot 🙈 Steve
Post by peddrotzr on May 18, 2022 22:34:14 GMT 1
TSA Kenny is a great guy and hope hes ok. As for Carbon cans will have these problems as I have mentioned before as the lower aluminum spigot isnst "usually long enough" to support the weight of the end can depending on the lenght of the can. then wear around the rivets ect ...... I had this back in 2011 on my bike and also took a video of a Aprillia RS485 with tyga cans in 2011 which wore out in less than 100 miles I fixed my bike at "Tractor Teds in Ramsey " just to get me home. once back home I fitted a "P" clilp and support strap and not had a problem since have had this on several other customers bikes all with different carbon cans Basically its the weight of the end can and the length of it on the rivets, similar to "force of moments" carbon cans might look good but........... Best regards Johnny C
Post by dusty350 on May 19, 2022 6:53:26 GMT 1
Post by liffy16 on May 19, 2022 10:27:46 GMT 1
Still no word off Kenny? hope he's ok 🤞
Post by vectisitch on May 19, 2022 10:34:15 GMT 1
Kenny answered the email. He doesn't do the tz style exit pipes and doesn't have any carbon cans in stock. I think I'll give the carbon a miss anyway after reading the comments about them. I can't believe no one does or will do the tz pipes.
