Post by urbantangleweed on May 18, 2022 5:42:03 GMT 1
Post by stirling11 on May 18, 2022 13:09:23 GMT 1
Banshee's don't have power valves so not sure if it would be compatible
Probably worth a shot
Post by reedpete on May 19, 2022 6:52:47 GMT 1
I love the description…. ‘Pulverised coal, oil fuel’
Features CDI box igniter, a device that provides sufficient energy to ignite pulverized coal, oil fuel and stabilize the flame in a flash. Great replacement for your old ones,high quality with long lifespan. Equipped with several connectors, just plug and play,low heat, low power consumption. Made of plastic material to ensure maximum strength and durability for long lasting usage.
Description Material: Plastic. Color: Black. Mounting Holes Distance(Center to Center): 85mm(3.34") OEM Part:For Yamaha 3GG-85540-10-00
Fitment: For Yamaha Banshee 350 YFZ350 2006 For Yamaha Banshee 350 YFZ350SE Special Edition 2006 For Yamaha Banshee 350 YFZ350SP 50th Anniversary Edition 2006
Post by jon on May 22, 2022 8:32:54 GMT 1
Banshee's don't have power valves so not sure if it would be compatible Probably worth a shot Is the power valve circuitry anything to do with the CDI? I didn’t think it was? Jon
Post by JonW on May 22, 2022 9:24:53 GMT 1
Banshee's don't have power valves so not sure if it would be compatible Probably worth a shot Is the power valve circuitry anything to do with the CDI? I didn’t think it was? Jon i think youre right Jon, its in the PV controller... feed from the revs comes in and then power to the servo goes out.
