dex46
Post by dex46 on May 16, 2022 20:56:23 GMT 1
Hi all Not posted for a few years but still been popping on every now and again for a snoop. I’m in the early stages of a Mito 350 build going to be running ignitech and power dynamo on my valve engine I’m intending to run a 4L0/4L1 loom as I think it will fit the bike better than a valve loom just want some advice on the reproduction loom’s which one are people using and recommend as I don’t want to be messing with 40 year old electric’s. Also planning on running TMX30s can I use a standard RD throttle cable with them.
Post by Norbo on May 17, 2022 8:43:15 GMT 1
Think id use the ypvs loom my self there is a reason people dont just swap the ypvs engine in an lc they have to use the loom as well the firing is not the same and the lc loom wont make the stator run correct .Having said that the lc looms you have seen are very good and as your fitting a vape you may get away with it but as its a ypvs bottom end get a ypvs vape
Post by bare on May 18, 2022 17:56:42 GMT 1
LC loom will make the YVPS stator run Fine. Does on mine. Only significant differences betwixt LC and Valvie loom is the few extra wires for the PV servo motor.
Post by muttsnuts on May 18, 2022 20:11:50 GMT 1
if you are running the ignitech then the LC loom will be more than good enough as you just wire the ignitech direct to the PV servo (5 wires) and your running a PD kit as well, so no issues with the stator side of the wiring as that goes direct to the ignitech as well
30mm TMX carbs are a great carb, but the stock cable won't work as is, I just make new cables up from the junction box to the carbs, but then I have cable making gear, so its easy for me to say !
dex46
Post by dex46 on May 18, 2022 21:34:00 GMT 1
Hi Dave thanks for the reply spoke to you a couple of weeks ago about my mito build (Andy down in Peterborough) I’ll be in touch shortly to get stuff sorted what I need so I can get most of the work done before I get it booked in for you to work ya magic
