Post by urbantangleweed on May 15, 2022 19:00:51 GMT 1
Had the opportunity to investigate the age old backlash situation yesterday. The engine I'm currently building is a Brazilian with backlash of 156, runs smooth and easy, no tight spots or discernible play (with engine built up but no cylinders on). Then I put on a brand new basket, backlash was now 158 and it was impossible to tell any difference from the 156.
Post by muttsnuts on May 15, 2022 19:05:26 GMT 1
generally backlash numbers between 150 to 160 tends to be fine, below 150 it starts getting very sloppy/noisy, above 160 things do start to get tight when turning over by hand, even tighter when the engine is running hot as things expand
Backlash
May 15, 2022 20:21:00 GMT 1
via mobile
Post by urbantangleweed on May 15, 2022 20:21:00 GMT 1
Cheers Dave. I got to thinking that probably 150 to 160 would likely be perfectly fine so it's interesting that you've discovered just that 👍🏻
