Post by JonW on May 23, 2022 3:09:27 GMT 1
They might just have glued em in as it was a sunday night and they didnt have an o ring handy... or they could be ruined and leak like sieves. I think we all know what you will do tho... get em out and then work out what you need to do to fix it, from a reglue to an insert via just a simple new o ring...
Post by 17again on May 23, 2022 7:19:48 GMT 1
They might just have glued em in as it was a sunday night and they didnt have an o ring handy... or they could be ruined and leak like sieves. I think we all know what you will do tho... get em out and then work out what you need to do to fix it, from a reglue to an insert via just a simple new o ring... yes but do i get them out? there pretty in there. i have tried a wood drift and a hammer
Post by JonW on May 23, 2022 8:23:00 GMT 1
I do wonder if that bathroom sealant remover would help? that or paint stripper?
Post by midlifecrisisrd on May 23, 2022 8:29:21 GMT 1
If it's soft silicone sealer simply leave overnight in a tin on petrol
If the bush has worn and been chattering it wears a groove in the barrel and is sloppy after that but hopefully just a shitty repair that a new bush and o ring will sort out
Post by 17again on May 23, 2022 16:32:38 GMT 1
they were in there pretty good and i used heat and a bit of force to get them out. there is some wear but i didnt think they are to bad? what do you think?
Post by midlifecrisisrd on May 23, 2022 18:09:05 GMT 1
They look fine
I've seen them with either a full groove where the o ring sits or worn away where the back of the bush has been chattering
Post by midlifecrisisrd on May 23, 2022 18:09:42 GMT 1
Oh and NK racing do the proper red silicone o rings
Post by 17again on May 23, 2022 18:49:24 GMT 1
Oh and NK racing do the proper red silicone o rings Steve thanks steve, what is the difference between these and the viton ones that norbo sells?
Post by midlifecrisisrd on May 23, 2022 19:36:40 GMT 1
Oh and NK racing do the proper red silicone o rings Steve thanks steve, what is the difference between these and the viton ones that norbo sells? Yamaha used to supply the red silicone ones but superseded to the black ones The silicone is softer so goes in better Strve
Post by 17again on May 23, 2022 20:15:39 GMT 1
thanks i will see if he has got some
Post by 17again on May 24, 2022 8:05:01 GMT 1
a nice guy called andy has found another old photo of this bike which keeps me a bit more drive to keep this project going.
Post by 17again on Jun 2, 2022 17:38:33 GMT 1
that is over 15 years of oil off the swingarm
Post by 17again on Jun 3, 2022 13:03:46 GMT 1
found some more motorvation today. the original builder still has another LC that looks very similar
Post by dusty350 on Jun 4, 2022 6:31:28 GMT 1
That looks nice. I've always liked early Pv wheels in an Lc - the original hybrid wheel swap !
Dusty🙂
Post by 17again on Jun 4, 2022 8:02:27 GMT 1
That looks nice. I've always liked early Pv wheels in an Lc - the original hybrid wheel swap ! Dusty🙂 yes it does look nice. are the tires and disc the same size?
Post by 17again on Jun 11, 2022 18:40:08 GMT 1
Post by 17again on Jun 11, 2022 18:46:40 GMT 1
Post by 17again on Jun 11, 2022 18:48:35 GMT 1
found these toggle switches on the tail piece possibly for the old nos system or something esle
Post by 17again on Jun 11, 2022 18:50:44 GMT 1
found a new air box but the snorkel is missing will it run ok if i up jet a bit?
Post by 17again on Jun 25, 2022 16:51:44 GMT 1
got the frame back now and is gloss black got a few bit back on now put some panels on today to see how i will look does anyone know what these wires are for? photos.app.goo.gl/UTWb2TKpdtjbo67Z6
Post by dusty350 on Jun 25, 2022 17:03:19 GMT 1
Plug is for oil sender that goes in the oil tank I believe Dusty
Post by 17again on Jun 25, 2022 18:10:08 GMT 1
Post by dusty350 on Jun 25, 2022 18:55:23 GMT 1
I still can't make out the wires, but its likely the indicator cancelling unit. Wires are yellow/red trace, white/green trace, brown, black and yellow/green trace
Dusty🙂
Post by 17again on Jun 25, 2022 20:59:04 GMT 1
I still can't make out the wires, but its likely the indicator cancelling unit. Wires are yellow/red trace, white/green trace, brown, black and yellow/green trace Dusty🙂 thanks dusty, you and others confirm this. i can forget and move on with it.
Post by 17again on Jul 2, 2022 17:55:55 GMT 1
Post by jessy03 on Jul 2, 2022 18:02:35 GMT 1
Small for me, doing a top job keep it up👍👍👍
Post by headcoats on Jul 2, 2022 18:03:59 GMT 1
Round,standard it's the law
Post by andy748 on Jul 2, 2022 19:05:29 GMT 1
I like round as Headcoats said, but out of the two, small for me, makes the rear look neater. Andy.
Post by jon on Jul 3, 2022 8:30:01 GMT 1
It’s funny isn’t it? We are all different. I really like the F/N 2 indicators. The small ones just look like cheap nasty generic items.
I have to agree with OEM units though as my preference. Hell I’m even going to use an uncut stem on my latest hybrid. Trying to keep as many things OEM to offset the other modifications.
Post by JonW on Jul 3, 2022 14:24:28 GMT 1
I agree with Jon, Ive done that 'big inds' look before and liked it.
I do like the F/N2 inds actually on this, its 'period' etc.
Didnt someone (Dusty?) find some smaller round ones from M and P or somewhere?
