Post by noonster on May 4, 2022 13:00:08 GMT 1
Bought some std 4l0 exhausts for my rd350lc
R/H fitted straight on no issues.
L/H does fit, but the rear bolt on the hanger is a struggle to get through the elongated slot, i can get it in by loosening the 2 foot peg hanger bolts.
But when i tighten everything up the exhaust touches the swinging arm. I can loosen manifold bolts of, rear exhaust nut, and i can turn the pipe away 1/4inch from swinging arm, but i hold it then try and tighten it,it swings back
Any advice, exhaust is the correct one, cant see anything obvious
Post by LC_BOTT on May 4, 2022 13:23:14 GMT 1
Have you checked the mounting bracket to see if it's slightly bent? Any road rash on the pipes might confirm this.
Post by noonster on May 4, 2022 17:08:52 GMT 1
pipe as no physical damage, i have bent the bracket slightly myself,trying to force end of pipe away from swinging arm.
But when i tighten, it moves back and touches
Post by LC_BOTT on May 4, 2022 20:01:44 GMT 1
It could possibly be the hanger brakets are bent, Do the hangers run straight/inline front to back, might be easy to see from the rear of the bike and compare each side??? There was a similar thread on here a little while ago I think.
Post by muttsnuts on May 4, 2022 21:08:09 GMT 1
might be the exhausts have been cut and shut to remove a broken baffle and they have not aligned the 2 halves before welding them back together - seen that a lot recently, check the wleds carefully and see if one is different to the rest, normally middle weld or one of the 2 either side of the mid section
