Post by mouse on Apr 17, 2022 6:24:20 GMT 1
A question for all you YPVS Gurus.
I need to replace the clutch cable in my black 4lo hybrid (YPVS engine). I would like a 31k type genuine clutch cable (NLA), so no right angle piece at the handlebar end and i believe people say either a R6 or YBR125 clutch cable work, if so which model and year please?
Many thanks Mouse
Post by Yogi on Apr 17, 2022 8:20:38 GMT 1
Hi Andy
The Ybr125 custom cable is the one I use but it’s a bit longer and has the 90% top 🥴
Matt 🐻
Post by mouse on Apr 17, 2022 10:19:49 GMT 1
Cheers Matt, knew i could rely on you!
All the best
Mouse
Post by midlifecrisisrd on Apr 17, 2022 10:45:16 GMT 1
The ypvs 51l cable is still available and sure I used it on my last LC/ypvs
Post by JonW on Apr 17, 2022 13:42:13 GMT 1
1UA is also avail.
The 51L doesnt have a drop in it as the 85 bikes had a slanted clutch perch that the 83/4 and 86-on dont use, theirs is straighter.
Post by mouse on Apr 18, 2022 6:51:47 GMT 1
Many thanks for the help chaps, it's what makes this forum!
Mouse
Post by jon on Apr 18, 2022 8:35:56 GMT 1
1UA is also avail. The 51L doesnt have a drop in it as the 85 bikes had a slanted clutch perch that the 83/4 and 86-on dont use, theirs is straighter. I didn’t think the 1UA cable was available for a year or so. I bought one a while back. Edit: just realised I was getting confused with throttle cables for some reason? Jon
Post by LC_BOTT on Apr 18, 2022 9:22:12 GMT 1
There's several new/genuine 1UA cables on fleabay still
Post by jon on Apr 18, 2022 9:41:03 GMT 1
A question for all you YPVS Gurus. I need to replace the clutch cable in my black 4lo hybrid (YPVS engine). I would like a 31k type genuine clutch cable (NLA), so no right angle piece at the handlebar end and i believe people say either a R6 or YBR125 clutch cable work, if so which model and year please? Many thanks Mouse I’ve heard of the R6 cable being used before. Apparently a threaded adjuster at the engine end. Don’t know if all years are the same though? Jon
Post by midlifecrisisrd on Apr 18, 2022 10:07:01 GMT 1
Yes, superseded to 01 on end but 1ua cable still available Steve
Post by ozzysbikes on Apr 22, 2022 6:38:24 GMT 1
I had to find a cable without the elbow on the lever end to suit the FZR400 front end on my F2 and I used a FZR400 cable, I did have to modify the cable holder at the engine end, I had to reduce the size of the hole in the holder which I did by filing flats on a washer and then brazing it in, cable was perfect length.
Post by Tobyjugs on Apr 22, 2022 21:28:24 GMT 1
I just buy second hand Yamaha R6 or Fazer cables and modify the end to suit Length ect.
