tezrhc
Post by tezrhc on Apr 16, 2022 13:48:05 GMT 1
I have noticed traces of oil from the final drive seal where the sprocket spacer is, not loads but was wondering if there should be an o ring where the spacer meets the bearing, looked on Fowlers parts list but nothing shown, but I’m not sure the parts catalogue is always correct. I’ve taken the bearing off to have a look.
O ring
Apr 16, 2022 14:41:29 GMT 1
via mobile
Post by midlifecrisisrd on Apr 16, 2022 14:41:29 GMT 1
No o ring
O ring
Apr 16, 2022 14:41:48 GMT 1
Post by jessy03 on Apr 16, 2022 14:41:48 GMT 1
No O ring, should be a half moon piece to locate the bearing in the crankcase. Jess
tezrhc
Post by tezrhc on Apr 16, 2022 14:44:59 GMT 1
I have noticed traces of oil from the final drive seal where the sprocket spacer is, not loads but was wondering if there should be an o ring where the spacer meets the bearing, looked on Fowlers parts list but nothing shown, but I’m not sure the parts catalogue is always correct. I’ve taken the bearing off to have a look. Cheers all, just needed that second opinion. 👍
O ring
Apr 19, 2022 18:41:17 GMT 1
via mobile
tezrhc likes this
Post by chrisg on Apr 19, 2022 18:41:17 GMT 1
I have put a tiny amount of yamabond on the spacer to bearing face in the past. Not entirely sure if oil can track throught the ID of the spacer. Probably the big seal weep. What is the spacer OD surface like?
Post by arrow on Apr 19, 2022 19:45:48 GMT 1
The spacer forms a seal against the bearing face, with the massive pressure of the sprocket nut, does it not?
tezrhc
Post by tezrhc on Apr 19, 2022 20:48:25 GMT 1
I have put a tiny amount of yamabond on the spacer to bearing face in the past. Not entirely sure if oil can track throught the ID of the spacer. Probably the big seal weep. What is the spacer OD surface like? Spacer is fairly new and in good condition.
