Post by noonster on Apr 11, 2022 16:02:14 GMT 1
rd350lc
have problems bleeding brakes, getting some resistance on the brake lever, but still a bit spongy.
Also noticed on one nipple even tho its tight still seeing slight weepish of fluid coming out of the nipple top
Post by stusco on Apr 11, 2022 19:13:13 GMT 1
You need to fix the leak first then try with the top off the reservoir, half pull the leaver quickly over and over you should see small bubbles appear from a small hole in the bottom of the reservoir ,do this until they stop hopefully the leaver should get less spongy then pull the leaver into the bars and secure with a tie wrap overnight,when you come back the next day you normally have a good brake
Post by JonW on Apr 11, 2022 23:23:32 GMT 1
What he said.
Post by tacky1 on Apr 12, 2022 1:22:29 GMT 1
Yup, Solid advice there....
