Post by 1966baz on Apr 9, 2022 16:24:41 GMT 1
Hi everyone , after 4 years I've got my mars out.Clean fuel, and usual cleaning and checking the carbs it will only run on choke.It's now tax and mot exempt and I plan on using it this summer .The heart and aorta are fine now after my type A aortic dissection.Cheers .
Post by midlifecrisisrd on Apr 9, 2022 17:04:30 GMT 1
I'd say pilots are blocked by the sounds of it
Either that or it's sprung an air leak but it would tend to rev quite a bit on choke
Post by steeley on Apr 9, 2022 19:05:28 GMT 1
I'd say pilots are blocked by the sounds of it Either that or it's sprung an air leak but it would tend to rev quite a bit on choke Steve Or check your fuel/link pipes . Had a bit of a mare last year with a couple of mine going for Mot . Rotted out rubber pipes on one from pet tap / vacuum to carb plus a link pipe on carbs on the other bike . FFS .ROTTED out . Hmmm not good .
Post by 1966baz on Apr 9, 2022 20:23:33 GMT 1
I will look tomorrow.Thanks mate.
Post by 1966baz on Apr 10, 2022 16:37:42 GMT 1
Hi Steve, it turned out the air vent in filler tap was blocked.Also one of the pilot jets was blocked even though I checked them.There is some crud in the tank so I intend cleaning it out and coating it shortly.Cheers Nick.
Post by steeley on Apr 10, 2022 17:08:52 GMT 1
Nice .
