Post by evochris on Apr 3, 2022 19:05:29 GMT 1
Hi all, as you may be aware I have had the F2 in the Hybrid build section I thought it would be a good idea to stick it in the finished Hybrid section, because it’s………finished. Thisis my first hybrid, I have built/refurbed many bike over the last 20 years but have to say this has been my most fun, due to the nature of the beast (2 stroke RD). The donor bike was a Bandit 400, the wheels and cycle parts are the same as the Rgv VJ21 only a different headstock and swinging arm, bearings and bushes etc. Every step of the way has been carefully thought about so it can be reversed with the minimal of work to standard spec (ish, not many green bolts here). Super pleased with the result, exactly as I imagined it to be. So, to everyone supported and encouraged through the build, I thank you all. The words of encouragement kept me on track. below are the before and after 33937F35-6ED4-4754-BD90-353C8080F988 by chris tring, on Flickr 6B12B8DB-DACC-46F1-A0E9-3A23646B2D82 by chris tring, on Flickr 79568340-0C1F-415D-A95B-F57A2C20226D by chris tring, on Flickr 0A9F0176-2E41-4F16-B96A-026655136B47 by chris tring, on Flickr 73BE9972-8D06-4E2A-BED2-E0729B7A84E0 by chris tring, on Flickr
Post by dusty350 on Apr 3, 2022 19:53:36 GMT 1
Really nice job
Post by evochris on Apr 3, 2022 20:08:10 GMT 1
Really nice job Thanks Dusty, nothing near the league you have been producing but I am working on it 😁
avb
andys vapour blasting
Post by avb on Apr 3, 2022 20:29:19 GMT 1
subtle i like how well does it go
Post by evochris on Apr 3, 2022 20:39:26 GMT 1
subtle i like how well does it go Cheers, it runs lovely, smooth and confident, better tyres have helped, feels a little more up to date.
Post by arrdy350 on Apr 4, 2022 7:27:22 GMT 1
It was a interesting build thread to read😃 Great job 👍
Post by 17again on Apr 5, 2022 17:15:53 GMT 1
i think that front and rear end is very good choice. looks a nice upgrade
moggy
Post by moggy on Apr 8, 2022 21:03:03 GMT 1
Really nice, i love the wheel colour
Post by ozzysbikes on Apr 15, 2022 22:44:52 GMT 1
Hi
Looks good, I've nearly finished my hybrid F2, will try post pictures when it's done, hopefully next weekend,
What pipes are you using ? They look good, I'm thinking of replacing my microns with some other expansion chambers ready for the engine upgrades (+2mm crank, +1.5mm bore and some porting work hopefully by Mick Abbey), already running Zeeltronic, V force 4 reed blocks and PWK 28MM carbs.
Thanks
Post by evochris on Apr 16, 2022 16:19:03 GMT 1
Hi Looks good, I've nearly finished my hybrid F2, will try post pictures when it's done, hopefully next weekend, What pipes are you using ? They look good, I'm thinking of replacing my microns with some other expansion chambers ready for the engine upgrades (+2mm crank, +1.5mm bore and some porting work hopefully by Mick Abbey), already running Zeeltronic, V force 4 reed blocks and PWK 28MM carbs. Thanks Look forward to seeing your build please put up some pics, sounds like a nice bit of kit. I fitted stainless midrange pipes from Norbo, think they are Muttsnutts pipes.👍
