kopite30
http://www.motomovers.uk
Post by kopite30 on Feb 26, 2022 19:11:54 GMT 1
I’m just getting all the parts together for lc hybrid Rgv vj22 front & rear end ie Banana swinging arm & vj22 forks yokes etc
What headstock bearing do I need to get buy as I’ve brought Rgv but not sure if there right for lc frame
Also looking for rearsets I have pair but not keen on them, was going to go Standard Lc,
I’m new to lc hybrid as you can tell, so any help would be appreciate
Cheers Mike,
Post by andy748 on Feb 26, 2022 20:54:00 GMT 1
Hi Mike, Get a standard headstock taper kit for a LC not RGV as the lower race is bigger, you will need a 5mm spacer below the lower bearing, if you need one i have one in the man cave you can have, i bought extras from Norbo. Andy.
Post by mouse on Feb 27, 2022 7:56:46 GMT 1
NK Racing does really nice rearsets for both 4LO and 31k frames.
Mouse
Post by JonW on Feb 27, 2022 23:15:44 GMT 1
Hi Mike, Get a standard headstock taper kit for a LC not RGV as the lower race is bigger, you will need a 5mm spacer below the lower bearing +1 Dont let anyone tell you different. Ive seen Fbers say to use RGV, total joke. Easy conversion, probably the 'easiest'...
