Post by copper99 on Feb 3, 2022 17:33:02 GMT 1
Friend of mine has asked me to look at his 80LC tomorrow, what are the standard carb settings for these, please.
Is their a sight glass ala the 350LC so you can see the slide is fully opening as well?
Thanks muchly
Post by guiri on Feb 4, 2022 20:37:09 GMT 1
Hi, No, the sight glass is to balance the carbs on a 350. if you look into a single carb you can see if it opens fully....
Post by copper99 on Feb 5, 2022 22:28:27 GMT 1
Hi, No, the sight glass is to balance the carbs on a 350. if you look into a single carb you can see if it opens fully.... Thank you. Do you know what size jeting it should be on as std, air screw settings ?
Post by badger1 on Feb 6, 2022 9:53:13 GMT 1
Not sure what rd80lc model your talking about but this is for the 11a/10x/10y model Not the same looking as a 125lc.
Post by copper99 on Feb 6, 2022 12:41:45 GMT 1
Not sure what rd80lc model your talking about but this is for the 11a/10x/10y model Not the same looking as a 125lc. Thats the kiddie...Thanks mate.
Post by badger1 on Feb 6, 2022 13:52:15 GMT 1
No worries
Post by copper99 on Feb 21, 2022 17:09:10 GMT 1
Can you clarify my thinking, took the carb off this 80 today, was full of green varnish from old(pre E10!) petrol. Im correct in thinking middle screw would be for idle adjustment and screw towards airbox end is the air screw? Alos, would you know if the tank should have a rubber to support it, this screw seems a little out of place and there is a small amount of movement up/down. Thanks.
Post by badger1 on Feb 21, 2022 18:11:38 GMT 1
Yeah middle one for tickover/idle adjustment, look down where the slide goes you should see it showing through, same as a bigger lc. And yeah you have the rear rubber mount missing I’ll try and find a photo of what you’re looking for.
Post by badger1 on Feb 21, 2022 18:15:17 GMT 1
Post by badger1 on Feb 21, 2022 18:16:41 GMT 1
Post by badger1 on Feb 21, 2022 18:17:11 GMT 1
Post by badger1 on Feb 21, 2022 18:21:32 GMT 1
And the other screw your correct is the air screw.
Post by copper99 on Feb 24, 2022 8:05:06 GMT 1
Thank you mate.
