Post by jessem on Feb 2, 2022 18:19:35 GMT 1
Does anyone know where i can buy a connecting rod for a 1985 30w rd80lc2 mine is pretty bad and rusted so i am looking for a replacement, doesanyone know a good website for these kind of parts?
Post by abar121 on Feb 3, 2022 20:52:27 GMT 1
I think it's sold with the crank direct from Yamaha. Check the parts catalogs at fowlers, CMSNL etc.
So probably down to getting either a 2nd hand crank for the RD / DT. Or call one of the companies that rebuilds cranks like PJ Engineers, Granpian etc and see if they can help.
Also try a wanted ad on here and other forums.
Post by guiri on Feb 4, 2022 20:33:53 GMT 1
No.. they are availabe from many sources the rd80lc2 engine is almost identical to the uk rd80lc and dt80lc engines. all interior parts are interchangeable. yambits have the part you want.. and there will be many more on ebay yambits.co.uk/rd80lc-conrod-kit-p-2434.html
wd40
Post by wd40 on Feb 9, 2022 19:03:40 GMT 1
If you order a 10x or 11a type conrond complete with the new little end you will see that the little end bearing is smaller compared to that as fitted to a standard 30w crank ie the 30w has a bigger hole in the conrod and takes a bigger little end bearing.
Post by jorjasfather on Feb 10, 2022 18:11:23 GMT 1
Hi there mate have you tried GRAMPON motor in Liverpool telephone is 01519315009 they should be able to sort you out
