Post by midlifecrisisrd on Jan 25, 2022 13:45:45 GMT 1
It was suggested there was a sticky thread started for parts from other bikes/sources for either NLA parts or cheaper alternatives
I'll leave it to Admin to decide whether to make it sticky or move to a section deemed more appropriate
All helpful posts welcome
Post by midlifecrisisrd on Jan 25, 2022 13:54:03 GMT 1
I'll kick it off with the clock damper rings on YPVS/TZR/FZR clocks which turn to snot and are NLA Suzuki GS500 ones fit perfectly and are still available Steve
Post by shaunthe2nd on Jan 25, 2022 14:39:48 GMT 1
Here is one for a headlight bowl for the 31k. Fowlers list them at £220, and Norbo shows them in his shop at £85 so Norbo's looks a good price for new. I'm told they can be bought in US for cheaper.
On ebay SH ones are typically listed at £50-£60 and often a bit scratched.
Instead look for an XJR400 its the same bowl as the 31k one, and usually much cheaper. I got a very good SH one for £17, including the brackets and fasteners.
Check they are marked 'YHA 167' on the rear and they should be correct.
Post by midlifecrisisrd on Jan 25, 2022 14:47:51 GMT 1
Agree with Shaun above
Fowlers are now up to £247 😱
XJR400 and R1z250 use them
Headlight unit is the same but no pilot light. Easy to drill a hole and use a push fit lamp holder
Inner rim is the same 29l part number
Outer rim is the same but silver
Post by mouse on Jan 25, 2022 15:08:23 GMT 1
A YB125 fuel cap is the same as an RD500 FZ750. I bought a Chinese copy for £12 and it works perfectly on my FZ!
Mouse
Post by muttsnuts on Jan 25, 2022 16:39:01 GMT 1
X7 tool kit is same as an LC virtually, just no C panner for the shock (who ever used it anyway ?), and no Yamaha on the bag, other than that, its the same kit, last one I bought from Robinsons was £25+postage !
Post by abar121 on Jan 25, 2022 16:51:41 GMT 1
Various XS / XJ speedometers are great to canabilise to repair / convert to miles, 4LO speedometers. Also later 400 Daytonas etc.
Some FZ750 speedometers can be used on later YPVS models. 150mph like the RD500, but with a solid red needle. I paint the needle white, then lightly remove the excess white paint on the tip, before it's dry. Works great.
Post by shaunthe2nd on Jan 25, 2022 17:05:20 GMT 1
I've tried XS400 clock and gears are wrong for 4L0 but ok for air cooled RD's. I think needle is ok for 4L0 if you need a needle. Avoid XJ600 clocks if you are looking for gear parts, they are green plastic ones and about 2mm too short for 4L0 and not suitable for RD AC either. Haven't tried other XS/XJ clocks for parts so can't comment on those.
Post by midlifecrisisrd on Jan 25, 2022 17:08:41 GMT 1
Not so much an alternative part but an alternative solution
A YPVS gear change shaft with the usual groove where the seal lip sits can be used in an LC engine
As the gearboxes are different widths the groove will be about 5mm past the seal
£100 saved
Post by abar121 on Jan 25, 2022 17:48:34 GMT 1
I've tried XS400 clock and gears are wrong for 4L0 but ok for air cooled RD's. I think needle is ok for 4L0 if you need a needle. Avoid XJ600 clocks if you are looking for gear parts, they are green plastic ones and about 2mm too short for 4L0 and not suitable for RD AC either. Haven't tried other XS/XJ clocks for parts so can't comment on those. I've used a MPH face from an XS400, on a 4LO, both are 120mph.
Post by 4l04ever on Jan 25, 2022 19:43:54 GMT 1
Sump plug washers :- I have previously been using the Honda crush washers for the LC/YPVS sump bolts, but found these on ebay :- www.ebay.co.uk/itm/164902339920I just got a pack of 10 for £3.39 delivered. They look identical to the Honda ones :-)
Post by 4l04ever on Jan 25, 2022 19:47:25 GMT 1
Output shaft bearing behind front sprocket. Just get a good branded 6305NR and remove the snap ring :-) Usually less than £10. e.g. www.ebay.co.uk/itm/174436960197£8.93 delivered from a proper bearing company, so should not be a Chinese fake...
zebec
Post by zebec on Jan 25, 2022 20:52:20 GMT 1
Interesting "A YPVS gear change shaft with the usual groove where the seal lip sits can be used in an LC engine As the gearboxes are different widths the groove will be about 5mm past the seal"
Does the reverse work.. As in, the LC shaft in a YPVS?
Post by muttsnuts on Jan 25, 2022 21:04:42 GMT 1
Interesting "A YPVS gear change shaft with the usual groove where the seal lip sits can be used in an LC engine As the gearboxes are different widths the groove will be about 5mm past the seal" Does the reverse work.. As in, the LC shaft in a YPVS? not as well as normally the shaft part on the LC is exposed to the elements and is generally corroded, whereas the YPVS one is inside the casing as the YPVS cases are approx 5mm wider, so the shaft where the seal sits is on nice clean metal normally
Post by midlifecrisisrd on Jan 25, 2022 21:09:50 GMT 1
I'd also say there won't be much left sticking through the left case to bolt the gear lever arm to
Post by 4l04ever on Jan 25, 2022 21:55:27 GMT 1
I'd also say there won't be much left sticking through the left case to bolt the gear lever arm to Steve The LC gear lever arm superseded to the YPVS one. You can tell if you have the superseded one as the groove for the bolt in the end spline is only on one side, rather than all the way round like the original 4L0 one.
Post by midlifecrisisrd on Jan 26, 2022 10:02:18 GMT 1
Even the YPVS shift shaft is a superseded item and is from the banshee
The original ypvs 29l part had the groove all the way round. Apparently those boys weren't trusted to know which way the gear lever went on 🙄
Post by oldbritguy on Jan 26, 2022 11:33:22 GMT 1
I did wonder about that. Obviously the quad boys need a little more support with their routine maintenance and assembly skills.
Post by oldbritguy on Jan 26, 2022 11:36:21 GMT 1
Agree with Shaun above Fowlers are now up to £247 😱 XJR400 and R1z250 use them Headlight unit is the same but no pilot light. Easy to drill a hole and use a push fit lamp holder Inner rim is the same 29l part number Outer rim is the same but silver Steve Have we identified a good alternative for the LC item? I have a mint headlight shell, new reflector and lens unit but need inner and outer rims. Even decent pattern? John
Post by midlifecrisisrd on Jan 26, 2022 12:34:52 GMT 1
Agree with Shaun above Fowlers are now up to £247 😱 XJR400 and R1z250 use them Headlight unit is the same but no pilot light. Easy to drill a hole and use a push fit lamp holder Inner rim is the same 29l part number Outer rim is the same but silver Steve Have we identified a good alternative for the LC item? I have a mint headlight shell, new reflector and lens unit but need inner and outer rims. Even decent pattern? John Think most just use the pattern items Just saw a nos inner rim but it was £75 😖 Steve
Post by oldbritguy on Jan 26, 2022 13:22:36 GMT 1
£75 ouch. Looks like a pattern job for now until something more akin to original turns up. John
Post by tonyd123 on Jan 27, 2022 11:29:01 GMT 1
Great tips, this is what we want Mods - please can we make this a sticky?
Post by evochris on Jan 27, 2022 16:10:24 GMT 1
this is excellent, once it gets a good amount of items it should be made into a list. I have found sticking the original Yamaha part number in fleebay brings up different bikes with some cheaper pricing.
Post by sp885 on Jan 29, 2022 4:50:18 GMT 1
X7 tool kit is same as an LC virtually, just no C panner for the shock (who ever used it anyway ?), and no Yamaha on the bag, other than that, its the same kit, last one I bought from Robinsons was £25+postage ! I bought one of these X7 toolkits about 5 years ago Dave for about that money from memory, like you say no C spanner and yeah did anyone use it, I've got a YSS shock now so it doesn't matter the spanners have made in Japan on them I'm sure
Post by 4l04ever on Jan 31, 2022 23:05:11 GMT 1
The genuine Mikuni VM16/F210 is exactly the same as the original 4L0 choke mechanism, but about a third of the Yamaha price.
fabiostar
the older i get the faster i was.
Post by fabiostar on Feb 5, 2022 22:49:29 GMT 1
great thread lads.... other than XJ550? the price of LC350 calipers is a tad salty.. im looking to add a second caliper on to a 250. anybody know other calipers that would match up to my single one?
dont really wana go the blue spot route.
Post by donkeychomp on Feb 5, 2022 23:46:46 GMT 1
An RD125LC brake light holder fits a 350LC with a little trimming. Even the mounting holes are the same. Added bonus is it recesses the rear light perfectly. How do I know? I did it.
Post by reedpete on Feb 6, 2022 0:08:49 GMT 1
great thread lads.... other than XJ550? the price of LC350 calipers is a tad salty.. im looking to add a second caliper on to a 250. anybody know other calipers that would match up to my single one? dont really wana go the blue spot route. The callipers from a 31K LC2 fit, generally much cheaper than the 4L0 LC ones
Post by JonW on Feb 6, 2022 1:17:14 GMT 1
great thread lads.... other than XJ550? the price of LC350 calipers is a tad salty.. im looking to add a second caliper on to a 250. anybody know other calipers that would match up to my single one? dont really wana go the blue spot route. The callipers from a 31K LC2 fit, generally much cheaper than the 4L0 LC ones Some say they work better too. There are also plenty of similar looking brake master cylinders for our bikes that Yamaha used so you can pick up a good value new one with a slightly different part number. This is very true of the later coffin style version, with a different first part of the no. which is great value from the usa.
Post by abar121 on Feb 6, 2022 12:31:58 GMT 1
I've used XJ750 front calipers on an LC in the past. Lots of other Yamahas of that age will work.
Also used XJ600 pre-diversion seat locks on an LC.
