Post by nomoreheros on Sept 23, 2021 11:02:59 GMT 1
Is this correct?...no gasket between the thermostat and cylinder head...seems not quite right to me... answers on a postcard please lol
Post by midlifecrisisrd on Sept 23, 2021 11:30:36 GMT 1
The thermostat has a rubber seal around it which seals the joint 😁
No gasket
Sept 23, 2021 11:59:58 GMT 1
via mobile
Post by nomoreheros on Sept 23, 2021 11:59:58 GMT 1
I knew you'd come to the rescue Steve...do you have a part number?
No gasket
Sept 23, 2021 12:26:49 GMT 1
via mobile
Post by midlifecrisisrd on Sept 23, 2021 12:26:49 GMT 1
The seal is part of the thermostat
I've never had to replace one
Post by reedpete on Sept 23, 2021 14:52:10 GMT 1
I’ve never had to replace one either…although I have removed a few 😂
Post by speedar on Sept 23, 2021 15:34:10 GMT 1
Think Norbo sells them.
No gasket
Sept 23, 2021 15:51:01 GMT 1
via mobile
Post by midlifecrisisrd on Sept 23, 2021 15:51:01 GMT 1
I’ve never had to replace one either…although I have removed a few 😂 I have removed the seal as the 50 degree snow mobile stat comes without the ring so you have to pinch it from a 71 stat Steve
Post by JonW on Sept 24, 2021 2:58:46 GMT 1
you can buy the seal separately if you need one, sometimes they are missing (who knows why, its the 35year old junk parts lots i buy i guess) or the alloy has oxidised and the seal looks all pitted, new ones are not silly money.
Post by bare on Oct 1, 2021 4:31:19 GMT 1
Identical seals to those fitted to SAAB thermostats. Could be others as well. But I have familiarity with Saab bits.. is all.
