garyd
Post by garyd on Sept 20, 2021 21:37:41 GMT 1
I had an RD 250C at the end of the 70's. It developed a fault where once fully warmed-up it became almost impossible to change gear. Instead of getting it fixed, I traded it in.
What would the fault have been?
Post by donkeychomp on Sept 21, 2021 21:24:43 GMT 1
All I can think of off the top of my noggin is low gear oil level.
Post by gazzatt2 on Sept 22, 2021 20:29:57 GMT 1
clutch not clearing - clutch plates distorted worm gear sticking
garyd
Post by garyd on Sept 22, 2021 20:43:29 GMT 1
It was my 2nd bike so I think I probably looked after the oil. I took it to a bike shop & the owner knew what it'd be, but I can't remember. I still have a momento, - a holed piston, - I was told it should have been subject to a recall for a thicker head gasket....the Dealer wasn't volunteering though....
garyd
Post by garyd on Sept 22, 2021 20:44:37 GMT 1
clutch not clearing - clutch plates distorted worm gear sticking What's the worm gear, gazzatt2 ?
Post by gazzatt2 on Sept 23, 2021 20:40:05 GMT 1
clutch not clearing - clutch plates distorted worm gear sticking What's the worm gear, gazzatt2 ? its what the clutch cable connects too behind the left hand cover and turns in to push the clutch rod in when the lever is pulled back
