Post by badger69 on Sept 18, 2021 16:53:46 GMT 1
Hi can anyone help, ive just removed the front of my headlight and on removing it found that the last owner was a total t**t, when i pulled the front of the light the small light bulb was hanging down, this has only one wire going to it, one has been cut, can anyone tell me what colour wires should go here and and can i get the small bulb holder from on its own , also how is the best way to pull these connectors apart because they dont wont to move at the moment, and dont wont to cause more damage., thanks all help thanked
fubars
Post by fubars on Sept 18, 2021 19:05:07 GMT 1
Does this help ?
Post by badger69 on Sept 25, 2021 18:07:42 GMT 1
Does this help ?
Post by badger69 on Sept 25, 2021 18:14:25 GMT 1
Thanks mate, picture great help, would you be able to show me a picture where a black wire goes, it's in a loom of 4 wires which go to the left hand side of the battery , there is I believe a relay which is held by a rubber strap and I have 3 wires going to it and a black wire going nowhere, can you show me where this wire goes to, I hope you can understand me, thanks a bunch for your help, I'm useless when it comes to wiring. Thanks stay safe.
Post by chrisg on Sept 25, 2021 18:17:46 GMT 1
Black is an Earthing wire.
Post by stusco on Sept 25, 2021 18:21:17 GMT 1
The earth (black) connects to a double round spade
Post by badger69 on Sept 25, 2021 22:22:15 GMT 1
The earth (black) connects to a double round spade Thanks, would you be able to show a picture of where it connects, as this black wire has a bullit connecter on it, and the connection looks original, many thanks. If I could have an email address I could send you a. Picture of the affending wire as I don't now how to put pictures on here, thanks stay safe everyone.
Post by oldelsieboy on Sept 26, 2021 8:04:44 GMT 1
The earth (black) connects to a double round spade Thanks, would you be able to show a picture of where it connects, as this black wire has a bullit connecter on it, and the connection looks original, many thanks. If I could have an email address I could send you a. Picture of the affending wire as I don't now how to put pictures on here, thanks stay safe everyone. Inside the headlamp bowl there is a 3 way female bullet earth terminal, both indicators & the headlamp pilot light connect to it. OEB
Post by badger69 on Sept 26, 2021 10:06:55 GMT 1
Thanks again you are a star, if I need more help you are the man, thanks mate much appreciated, stay safe.
Post by 4l04ever on Sept 26, 2021 10:46:52 GMT 1
The wire with the blue ring terminal is the side light ground connection you are referring to.
It should not be a ring terminal connected to the headlight bolt, as that may be insulated by the paint on the headlight brackets. It should have a male bullet connector plugged into the highlighted 3-way female connector highlighted in red by OEB.
Cheers
Post by badger69 on Sept 26, 2021 13:06:03 GMT 1
The wire with the blue ring terminal is the side light ground connection you are referring to. It should not be a ring terminal connected to the headlight bolt, as that may be insulated by the paint on the headlight brackets. It should have a male bullet connector plugged into the highlighted 3-way female connector highlighted in red by OEB. Cheers Thanks mate I was woundering if the head light bolt connection was not suitable, can you help me with another matter, I'm trying to locate my temperature sensor cable but it's been cut, I followed it from clocks to headlight and then the red and green wire from. The four block connector goes down main loom, but doesn't come out near the coil like it should, if I cut and connect a new feed just before it goes down loom and connect new wire this will work ok yes, can you tell me what size wire I need to purchase and what size is the terminal which connects to the sensor on the head, hope you can help thanks I only need a few feet of cable I think, many thanks for you great help, thanks stay safe.
Post by 4l04ever on Sept 26, 2021 21:41:52 GMT 1
Post by JonW on Sept 27, 2021 2:49:50 GMT 1
If you do need a spade connector dont get the blue or red plastic things, buy some that are crimped and have clear rubbery covers like OEM.
I agree with Rob that earth wire to the headlight bowl bolt is a no-no, always use the connectors Yam intended. You can run extra earthing wires, but that one is a poor choice.
Post by badger69 on Oct 4, 2021 14:38:48 GMT 1
Post by badger69 on Jun 4, 2022 14:17:03 GMT 1
Hi can someone help with more crap wiring question, the live wire from the side light will this go straight to the left hand switch gear or does it go some where between, as mine has been butchered and is a black wire not red and blue, many thanks stay safe
Post by oldelsieboy on Jun 4, 2022 16:13:17 GMT 1
Hi can someone help with more crap wiring question, the live wire from the side light will this go straight to the left hand switch gear or does it go some where between, as mine has been butchered and is a black wire not red and blue, many thanks stay safe It should attached to a flying lead from the ignition switch terminal block. OEB
