Post by buck1963 on Sept 17, 2021 21:14:15 GMT 1
hiya folks,has anybody any idea what size they are?thanks
Post by muttsnuts on Sept 18, 2021 16:35:10 GMT 1
I've got 50 coming on Monday, they are an odd size, 6.88mm ID x 1.18mm cs
Post by buck1963 on Sept 18, 2021 22:30:24 GMT 1
I've got 50 coming on Monday, they are an odd size, 6.88mm ID x 1.18mm cs Hiya ,,could you sell me a couple ,thanks
Post by muttsnuts on Sept 20, 2021 9:45:27 GMT 1
I've got 50 coming on Monday, they are an odd size, 6.88mm ID x 1.18mm cs Hiya ,,could you sell me a couple ,thanks Hi Doug, they should be here today, I'll check they are correct etc and then give you a shout Regards Dave
Post by buck1963 on Sept 20, 2021 20:48:37 GMT 1
Thanks Dave
Post by muttsnuts on Sept 21, 2021 21:29:42 GMT 1
quick update, the ones I ordered fit nicely in a good body, but are like replacement ones a little slack on a worn body, but I've checked with the supplier and they do a wider cross section O ring in the same ID and material, so I am going to order some of them and see how they fit, they will be 0.3mm bigger in OD than stock ones, which should take up any wear, I'll try and get them ordered tomorrow and will keep you posted when they arrive
Post by buck1963 on Sept 25, 2021 19:01:16 GMT 1
quick update, the ones I ordered fit nicely in a good body, but are like replacement ones a little slack on a worn body, but I've checked with the supplier and they do a wider cross section O ring in the same ID and material, so I am going to order some of them and see how they fit, they will be 0.3mm bigger in OD than stock ones, which should take up any wear, I'll try and get them ordered tomorrow and will keep you posted when they arrive thanks Dave,much appreciated
