Post by kman on Sept 17, 2021 8:37:03 GMT 1
Hey, whos using what intakes to suit 34mm to rz banshee reeds. Cheers
Post by jon on Sept 18, 2021 8:37:26 GMT 1
I think most use the billet manifolds?
Post by JonW on Sept 19, 2021 1:32:42 GMT 1
yep billet from Wicked and other banshee suppliers
Post by Norbo on Sept 19, 2021 8:24:18 GMT 1
I have them listed on my site
Post by kman on Sept 20, 2021 5:00:09 GMT 1
these are to fit to modified lc barrels, i'm not sure if the one piece intakes will fit. Cheers
Post by dusty350 on Sept 20, 2021 6:56:00 GMT 1
I think the Lc are the same as the Ac, and the ones I got fit my 400 no problem. It's Pv reed cages that wont fit Lc inlets without modifying. Dusty
Post by Tobyjugs on Sept 20, 2021 7:14:41 GMT 1
I understand your problem.
The carbs will probably hit the chassis rail, you need single rubber inlets, short as possible. I have two, i'm not sure where they came from, Possibly a TZ750?.
The billit manifolds are normally constructed from two pieces, if you junk the front part i think they will still be too long. Get in touch with Fondseca they might be able to help out.
Post by dusty350 on Sept 20, 2021 8:00:50 GMT 1
The 2 part billet manifolds incorporate a cross over machined housing, to replace the cross over tube, and are deeper. The billet inlet I used is a single piece and therefore not as deep; 20210403_160949 by dusty miller, on Flickr And the deeper 2 piece, albeit with deeper Vforce cages; 20190926_115141 by dusty miller, on Flickr
Post by mickross355 on Sept 20, 2021 11:51:24 GMT 1
I just purchased wicked manifolds, vforce4 reeds and new 34mm PJ carbs The cables interfere with the frame rail on my rz pretty badly. Now to figure out a work around. Moving the reg/rec and running the cables over the frame rail may see me out of trouble.
Post by JonW on Sept 20, 2021 13:41:25 GMT 1
I just purchased wicked manifolds, vforce4 reeds and new 34mm PJ carbs The cables interfere with the frame rail on my rz pretty badly. Now to figure out a work around. Moving the reg/rec and running the cables over the frame rail may see me out of trouble. Have you fitted 45deg angled tops to the carbs?
RZ INTAKES
Sept 20, 2021 18:22:35 GMT 1
via mobile
Post by srhiskx on Sept 20, 2021 18:22:35 GMT 1
I have PWK28’s on my RZ and they came with 45’s degree angle and tried to fit a billet intake and they hit the frame. I think you have to use 90 degree elbows for them.
Post by JonW on Sept 21, 2021 0:59:51 GMT 1
Interesting. I have an RZ motor in an LC with Athena 421, wicked x-over and 34 PJs, the carbs dont hit the frame or the clutch arm, but the filters did so I used foam units.
Post by mickross355 on Sept 22, 2021 8:27:48 GMT 1
This is the problem I’m facing with the cables as supplied.
Post by JonW on Sept 22, 2021 13:31:40 GMT 1
What's under those boots? Can you fit a shorter 45deg adaptor to go under the frame rail?
Post by mickross355 on Sept 23, 2021 8:53:11 GMT 1
What's under those boots? Can you fit a shorter 45deg adaptor to go under the frame rail? Not sure Jon. I’ve never really messed with cables before. These are the cables wicked supplied in the kit. The steel cable ends are quite high
