Post by markrd250lc on Sept 10, 2021 21:23:21 GMT 1
Just went to Lidl and they have on offer 350 assorted stainless washers, flat/spring pack M4 M5 M6 M8 M10 M12 £2.50
just be aware the nut packs are galvanised but still handy 128 assorted, nyloc and standard M4 M5 M6 M8 M10 M12. £2.50
Mark
Post by kirkhd on Sept 19, 2021 17:36:24 GMT 1
Thought i's pick some of these washers up from our store that re-opened after major refurb on Thursday but couldn't find any
Post by steve h on Sept 19, 2021 20:28:10 GMT 1
Bloooooerchhhhhhh! A nut aint a nut unless it's green... a pistachio is both though...
If you dont believe me ask the Green passivate Society. (they are the ones sat in the corner boiling in their own urine at the mere sight of a stainless fixing...wearing tank tops, and more than likely something beige coloured)
Post by steve h on Sept 20, 2021 19:08:08 GMT 1
Anyone had a go at passivating new BZP fixings? Could be handy on say, side cases.
Post by midlifecrisisrd on Sept 30, 2021 15:21:53 GMT 1
Anyone had a go at passivating new BZP fixings? Could be handy on say, side cases. Yes I've had a bash with varying results A lot won't take it at all, other stuff takes the colour but not on the sharp edges Best result was from dipping them for 5 - 10 seconds in acid to soften the existing passivate layer and give it something to bite into Steve
Post by steve h on Sept 30, 2021 15:30:21 GMT 1
Nice one Stevie. Was it you who posted up a home passivating set up years ago? Might have a go at passivating side casing screws, have some bzp ones.
Post by midlifecrisisrd on Sept 30, 2021 18:07:41 GMT 1
Nice one Stevie. Was it you who posted up a home passivating set up years ago? Might have a go at passivating side casing screws, have some bzp ones. Yes, think that was me Got all 4 highly toxic colours 😁 Just pop them in the acid till they start to fizz, quick fresh water rinse then into the olive for 1 - 2 minutes. Give them a good jiggle as air tends to get trapped in the heads. I use a sieve Rinse again, shake off the loose water then leave them somewhere warm to air dry over night to let it harden Don't heat them as they discolour Don't wipe them or some will come off Steve
