Post by badger69 on Sept 4, 2021 14:38:13 GMT 1
Hi everyone, can anyone help, my RD LC 250 has about a half inch to a inch gap at the rear, this looks to high, the gap between rear panel and seat looks to much , this Nike is new to me so I don't know how it was put together, if someone can help and you require a picture give me your email address and I will email a picture, all help thanked, keep safe all.
Post by veg on Sept 4, 2021 14:57:25 GMT 1
New seat cover has been fitted at a guess and is too tight, you should be able to release it then recover less tightly.
Post by blaine on Sept 4, 2021 15:59:04 GMT 1
Another check is that the plastic seat base is not pressed against the inner mudguard.
I've only had this the once the inner mudguard had been modified and the back of the seat base was pressed against it.
Post by badger69 on Sept 4, 2021 16:36:16 GMT 1
New seat cover has been fitted at a guess and is too tight, you should be able to release it then recover less tightly. Hi thanks for reply, the seat cover is original, thanks stay safe
Post by badger69 on Sept 4, 2021 16:39:14 GMT 1
Another check is that the plastic seat base is not pressed against the inner mudguard. I've only had this the once the inner mudguard had been modified and the back of the seat base was pressed against it. Hi thanks is there a picture I can view to how it should be with the seat off, many thanks, if you can't send pictures here my email is badgerjum7@hotmail.co.uk many thanks again
Post by blaine on Sept 4, 2021 16:44:58 GMT 1
Not on my current bike...it's modified 🙂
Post by badger69 on Sept 4, 2021 16:48:56 GMT 1
Not on my current bike...it's modified 🙂 Thanks anyway mate, will have a look to see if I can find the issue, stay safe.
jam911
Post by jam911 on Sept 4, 2021 20:21:33 GMT 1
I feel your pain.
I brought a standard recovered seat as my bike came with an aftermarket one.
The fit was bad with large gaps on the side and back.
I took it apart and tried heating it and cable tying it to the bike to fit.
This didn't work.
I contacted the guy I got it from and he said it fitted his bike fine.
In the end I sold the seat. and lost money on it and it was now in bits.
Then a very kind member on here said he had some seats and I could buy one.
We tried 6 different seats and they all fitted slightly differently.
Finally an original one (and the most expensive of course) fitted perfectly.
The moral of the story is seats are a pain and they all seem to be a little bit different.
If you want it perfect it will cost you and will be frustrating along the way.
I think if you managed to find a NOS one it would still be a gamble as to wether it would fit your actual bike or not.
Post by Bertie Wooster on Sept 4, 2021 21:34:36 GMT 1
I used a heat gun on back of seat but not too much incase it melted then turned it over and pressed down hard on back of seat while it cooled now no more gap
Post by 29davyt on Sept 4, 2021 22:08:26 GMT 1
If you can sit on it and ride the bike ok I wouldn’t worry to much about it, they are all different as previously said ..
Post by Tobyjugs on Sept 5, 2021 0:24:38 GMT 1
Sometimes you can loosen the subrame and lift it up to reduce the seat gap.
Post by 4l04ever on Sept 5, 2021 11:10:24 GMT 1
If the seat can be pressed down to close up the gap, then you may be able to alter the catches to pull it further down.
Post by badger69 on Sept 5, 2021 15:05:04 GMT 1
I feel your pain. I brought a standard recovered seat as my bike came with an aftermarket one. The fit was bad with large gaps on the side and back. I took it apart and tried heating it and cable tying it to the bike to fit. This didn't work. I contacted the guy I got it from and he said it fitted his bike fine. In the end I sold the seat. and lost money on it and it was now in bits. Then a very kind member on here said he had some seats and I could buy one. We tried 6 different seats and they all fitted slightly differently. Finally an original one (and the most expensive of course) fitted perfectly. The moral of the story is seats are a pain and they all seem to be a little bit different. If you want it perfect it will cost you and will be frustrating along the way. I think if you managed to find a NOS one it would still be a gamble as to wether it would fit your actual bike or not. Thanks mate sad story, I will try and get on with it as it is, I will be selling it soon anyway, thanks stay safe mate
Post by badger69 on Sept 5, 2021 15:07:20 GMT 1
If the seat can be pressed down to close up the gap, then you may be able to alter the catches to pull it further down. Thanks yes I can press it down by hand, how is best to adjust catches, do they have any adjustments on them, thanks for reply, stay safe.
Post by badger69 on Sept 5, 2021 15:09:21 GMT 1
Sometimes you can loosen the subrame and lift it up to reduce the seat gap. Thanks I will give all these suggestions ago, will let you know how I get on, many thanks stay safe.
Post by 4l04ever on Sept 5, 2021 20:29:25 GMT 1
If the seat can be pressed down to close up the gap, then you may be able to alter the catches to pull it further down. Thanks yes I can press it down by hand, how is best to adjust catches, do they have any adjustments on them, thanks for reply, stay safe. You can get the hooks on the bottom of the seat welded up a bit so the step is a bit higher. To work out how much you need to go, you can space the catches on the frame down by putting washers between the frame catches and the frame.
Post by badger69 on Sept 11, 2021 9:34:48 GMT 1
I used a heat gun on back of seat but not too much incase it melted then turned it over and pressed down hard on back of seat while it cooled now no more gap Thanks I will give this ago, as it's a cheap option and may work for me,thanks again and stay safe.
Post by peddrotzr on Sept 11, 2021 10:23:31 GMT 1
As mentioned above I loosened the subframe and lifted it up also rather than fit washers under the seat catches I made a metal plate to fit between the frame and the catch so its not as obvious and just painted it black to hide it
Post by markhoopy on Sept 19, 2021 16:52:41 GMT 1
A couple of photos of the offending item.
Post by robin on Sept 19, 2021 19:51:35 GMT 1
I had the same issue, I stacked up washers to lower the seat catches, once I had worked out how much lower I needed to be, I made a spacer plate, looks so much better now.
Post by badger69 on Sept 20, 2021 17:25:02 GMT 1
I had the same issue, I stacked up washers to lower the seat catches, once I had worked out how much lower I needed to be, I made a spacer plate, looks so much better now. Thanks Robin, this is what I'm going to try over this weekend, I think this will sort out the issue, keep safe,and thankssss
