Post by chrisg on Aug 25, 2021 18:47:17 GMT 1
Hi, is there a secret to removing the carb float pin on a 4L0 00 carb. AC carb pins just slide out. My pin appears to be held in place and also has a flange a bit like a nail. Any advise welcome? Thanks
Post by midlifecrisisrd on Aug 25, 2021 19:00:17 GMT 1
Using long nose pliers squeeze the end inward. The last bit goes in with a click so once you move it a mm or so it just falls out
Don't tap it or you can break the carb lug it goes through
Post by chrisg on Aug 25, 2021 20:10:23 GMT 1
That was my concern, breaking the mount. Managed to do it. With age comes patience, I hope. Thanks
