Post by ziplock on Aug 25, 2021 11:43:57 GMT 1
Hi All First post... I'm rebuilding my '82 LC 250 and pretty much have everything but I've never liked the standard pipes that I have, so want something a bit trick. I'd love to have some 250GP (pre MotoGP era) style ones, swept up with end cans, a bit like a TZ. Or even both pipes exiting same side? I've contacted loads of engineers and bike shops, none can help. Can you help and let me have any recommendations that actually fabricate / sell? I've seen Norbo's shop trick parts but don't like the cross-over style. I have been topping up the piggy bank for this...
Post by julianboolean on Aug 25, 2021 11:55:21 GMT 1
Post by badger1 on Aug 25, 2021 11:58:56 GMT 1
Post by Chewie01 on Aug 25, 2021 12:33:42 GMT 1
Post by midlifecrisisrd on Aug 25, 2021 12:36:59 GMT 1
Think you have enough to be going on with there lol
More pipes now than there ever was đŸ˜†
Post by midlifecrisisrd on Aug 25, 2021 12:41:12 GMT 1
I'd also say Be careful fitting expansion chambers to a 250
Most of these are designed for the 350 and will work in a 250 but you will lose quite a bit of midrange
Personally I'd look at Gibson for either Allspeed style pipes or the separate silencer style
These were not massive performance pipes on a 350 but should work well on a 250
Also speak to Dave Muttsnuts
Think he was looking at his midrange 350 pipes on a 250 to see how they went on the dyno
Post by julianboolean on Aug 25, 2021 15:15:38 GMT 1
In 1985 I fitted a pair of big can Microns to a 250LC, it went well at the top end (indicated 115mph, it indicated 100 with standard pipes), there was no midrange power, a pair of Lomas pipes had a similar effect on my stage 2 350 YPVS, it went from a 125 top speed to 135, with no mid range.
Post by reedpete on Aug 25, 2021 18:18:01 GMT 1
The chamber geometry is fine, it’s just the stinger is too big and not enough mid range back pressure….
