Post by tacky1 on Aug 23, 2021 23:14:35 GMT 1
Well seeing that I reside stateside, this is an RZ500, Its a bit of a mess TBH, A lot of metal was removed from the frame, brackets etc, Im not doing a stock build, I will be replacing the YZR fairing as it looks like shoite..... Its a race fairing and its just tatty, I have a nice RZ fairing ill fit, Ill leave the tail on it though, The original subframe is gone and I like the look of the YZR one, Ill mod it though so its a little more fitted and solid on there and re-cut and weld the upper exhausts so they fit straight and cleaner.. Engine has new cranks and pistons, so that's a lot of work not to be done, Suspension is Priller RSV1000 and the wheels are actually in like!! Chain lines up with a machined front sprocket, So that saves a lot of work. Let the games begin.........
Post by JonW on Aug 24, 2021 0:45:27 GMT 1
Great project!
Post by oldbritguy on Aug 24, 2021 20:09:27 GMT 1
You are not hanging about Tacky. I cannot believe the pace that some members are turning out absolutely top builds Looking forward to see what you do with this one John
Post by tacky1 on Aug 24, 2021 22:22:48 GMT 1
You are not hanging about Tacky. I cannot believe the pace that some members are turning out absolutely top builds Looking forward to see what you do with this one John I get bored very quick John, plus, if I rest my arse at all in the house, the missus will nail me with jobbies
Post by donkeychomp on Aug 24, 2021 22:35:27 GMT 1
Wow! Personally I really like the body kit. Looking forward to see what you do with it all.
