Post by 4ce on Aug 15, 2021 21:23:50 GMT 1
Needing some of your knowledge please. Building an ex racing LC from boxes with loads of parts missing. On the wiring loom below the coil are 5 multi blocks, 1 is for the coil and I think 1 is for a self cancelling indicator unit. What do the other 3 connect to?
Post by shaunthe2nd on Aug 15, 2021 21:54:26 GMT 1
From memory the LH and RH switch gear connect into these. One side has 2 connectors, the other 1.
Post by 4ce on Aug 15, 2021 22:39:14 GMT 1
Thanks Shaun, not got the switches on yet so probably right.
Post by JonW on Aug 24, 2021 0:59:12 GMT 1
If you look at the wiring diagram you can see the blocks by the number of wires and their colours, should be able to work out what they go to. grab some masking tape and start marking out what is what, will save you a lot of time and hassle later.
