Post by alext900 on Aug 9, 2021 19:36:16 GMT 1
hi all I have recently taken ownership of an LC framed YPVS engine hybrid with lots of new shiny bits like metmachex sw arm , ohlins shock GSXR forks RS250 wheels etc which i bought from my lad Peter AKA purpletoddy1981.
I need lots of bits to complete the project many of which will i am sure be lying around in various garages around the country (s)
if you have any that you wish to sell on please advise via PM!
carbs exhausts (after market expansion chambers not original ones) wiring loom YPVS preferred i think! rear part of mudguard air box fuse box cover
Also advice on a few things! clocks aftermarket? what would you go for? headlight / brackets 48.8mm tube upper and 52.8 lower on my forks
I have asked Norbo about new water pump, casing and a few other new bits
will add pics when i get around to it!
cheers
Post by dusty350 on Aug 9, 2021 20:02:50 GMT 1
Speak to Dave - Muttsnuts regards carbs and pipes. Digital Speedos do loads of trick instruments and also do fork clamps for headlights www.digital-speedos.co.uk/Get to 10 posts and you can access the Classifieds section on the forum Dusty
Post by alext900 on Aug 10, 2021 11:53:57 GMT 1
Thanks Dusty will have a look!
Post by alext900 on Aug 10, 2021 12:33:53 GMT 1
Post by alext900 on Aug 10, 2021 12:45:03 GMT 1
Post by Yogi on Aug 10, 2021 16:14:12 GMT 1
Good luck with the build Matt 🐻
Post by Yogi on Aug 10, 2021 16:15:02 GMT 1
Post by 17again on May 26, 2022 7:30:53 GMT 1
interesting will be watching this one. nice colour frame
