Post by Mr Kipling on Nov 19, 2021 19:36:01 GMT 1
Bike is looking great keep up the nice work.....
Rob123
Post by Rob123 on Dec 14, 2021 12:44:46 GMT 1
Little update on this I wanted to check what specifications I have on this engine before I go any further. Using a 0.6 base gasket 22cc domes here's what I have managed to figure out. Squish gap : around 1mm Exhaust duration : 192 degrees Transfer duration : 124 degrees Blow down : 33 degrees Uncorrected compression ratio 13:4:1 Corrected compression ratio 7:4:1 From what I've read these results all seem to be in the ballpark for the engine to run okay and be safe. I realy wanted to have a go at building a set of pipes so I bought: Sheet of 1.2mm mild steel Slip roller 12" Disc sander. Using a online expansion chamber calculator I entered my port timings and calculations and have been able to make a fairly accurate set of pipes. It's been a compromise of actually getting the sizes and shape to fit the dimensions of the frame,swingarm,chain centre stand and side stand. Starting with cardboard templates adjusting and making changes as we're needed ive been able to acheive a decent looking set of pipes I'm realy happy how there turning out . I just hope they perform well I can make changes So these are going to be a test set and hopefully get it on a dyno to see how good/bad they perform. I'm also making the silencers and am realy happy with these they'll be fairly loud tho I think. I have just bought a cheap tig welder so waiting for that to come and will hopefully be able to do a decent job of welding the cones up fully. I've never done tig welding so im excited to give it a go. I may be asking for some tips from you Chris (sidney81)😉 Cheers Rob 👍
Post by sidney81 on Dec 14, 2021 13:18:20 GMT 1
Thats fantastic work there,and them roller's are the tits !!! I'd of loved to of made my own like that but I'm not clever enough to work all the volume's out etc 😂, credit to ya looking great 😎👌
Rob123
Post by Rob123 on Dec 14, 2021 13:36:26 GMT 1
Thanks Chris I'm no Einstein mate 😂 im sure you could if you put your mind to it the computer does all the hard work well I say that I think the hardest part is the welding 😉.
Post by donkeychomp on Dec 14, 2021 22:25:33 GMT 1
Bloody hell Rob. Some fantastic work there mate.
Rob123
42l Build
Dec 14, 2021 22:59:17 GMT 1
via mobile
Post by Rob123 on Dec 14, 2021 22:59:17 GMT 1
Bloody hell Rob. Some fantastic work there mate. Alex Thanks Alex much appreciated 😀👍
Post by Tobyjugs on Dec 14, 2021 23:10:52 GMT 1
Hi Rob I think it's great that you are doing it yourself and i love the shape of those pipes. From the specs you posted up, the uncorrected compression ratio looks too high. I ended up lowering mine to about 11.5:1 (I think) i need to find my notes. I went from 23cc domes to 26cc. I cant comment on corrected compression ratios but lowering my uncorrected compression ratio helped the engine rev better. I also altered my exhaust port duration from 194 to 196 degrees Also i measured the combustion space above the piston crown with oil as only using the dome cc wil give a slightly different ratio. Sorry if i'm teaching grandad to suck eggs. Keep up the good work.
Rob123
42l Build
Dec 14, 2021 23:59:54 GMT 1
via mobile
Post by Rob123 on Dec 14, 2021 23:59:54 GMT 1
Hi Rob I think it's great that you are doing it yourself and i love the shape of those pipes. From the specs you posted up, the uncorrected compression ratio looks too high. I ended up lowering mine to about 11.5:1 (I think) i need to find my notes. I went from 23cc domes to 26cc. I cant comment on corrected compression ratios but lowering my uncorrected compression ratio helped the engine rev better. I also altered my exhaust port duration to 196 degrees Also i measured the combustion space above the piston crown with oil as only using the dome cc wil give a slightly different ratio. Sorry if i'm teaching grandad to suck eggs. Keep up the good work. Not at all Tony all advice is much appreciated I'm learning all this for the first time so am glad to hear other people's thoughts and ideas. I did work out the trapped volume of the combustion chamber using the method that you used by sealing the piston with grease at tdc then filling up with oil, this came out to a reading of 17cc meaning the piston crown volume was 5cc. I'd doubled checked the dome was 22cc with sparg plug in upside down and filled with oil and it was 22cc. I was going to ask you when you filled up the dome via spark plug with oil id noticed you had filled to the top of the spark plug threads. Looking at a few different people doing this and some filled to the top of thread some at the bottom. I ended up subtracting the amount of oil that was filling were the spark plug goes which was 2cc. A couple of pics of the calculator I'd used I'd inputed deck height as 0 and piston crown at 0 as I'd worked it out and subtracted it already off the dome volume. Cheers Rob
Post by cb250g5 on Dec 15, 2021 9:28:38 GMT 1
Ooh - slip rolls. You don't live anywhere near Lincoln do you? I have a job coming up where I need to roll some brass....
Rob123
42l Build
Dec 15, 2021 18:30:53 GMT 1
via mobile
Post by Rob123 on Dec 15, 2021 18:30:53 GMT 1
Ooh - slip rolls. You don't live anywhere near Lincoln do you? I have a job coming up where I need to roll some brass.... Not too far im in Hull let me know 👍
Post by cb250g5 on Dec 15, 2021 19:35:20 GMT 1
Ooh - slip rolls. You don't live anywhere near Lincoln do you? I have a job coming up where I need to roll some brass.... Not too far im in Hull let me know 👍 Will do. Month or so away, at best. Thanks
Rob123
42l Build
Dec 16, 2021 13:34:50 GMT 1
via mobile
Post by Rob123 on Dec 16, 2021 13:34:50 GMT 1
Post by sidney81 on Dec 16, 2021 13:35:50 GMT 1
Let's see how this goes then for £170 I'm expecting brilliant results 😂 £170 😂bloddy hell ,looks ok ,has it got HF start ? Not scratch start ?
Post by sidney81 on Dec 16, 2021 13:37:15 GMT 1
Just read the e bay add ,it has lol well worth it 👍
Rob123
Post by Rob123 on Dec 16, 2021 13:42:20 GMT 1
Just read the e bay add ,it has lol well worth it 👍 Get ready for that weld porn matey 😬😂
Post by sidney81 on Dec 16, 2021 13:48:19 GMT 1
Good luck 🤞 have a practice on some scrap ,youl get the hang of it , it will soon look like this 😉😉👍
Rob123
Post by Rob123 on Dec 16, 2021 13:51:33 GMT 1
Good luck 🤞 have a practice on some scrap ,youl get the hang of it , it will soon look like this 😉😉👍 ffwwwoooaaarrr stunning that Chris 😍 👍
Post by sidney81 on Dec 16, 2021 13:57:05 GMT 1
Good luck 🤞 have a practice on some scrap ,youl get the hang of it , it will soon look like this 😉😉👍 ffwwwoooaaarrr stunning that Chris 😍 👍 Thanks bud ,not so Glamorous today ,I'm bolting mild steel angle to the floor in a shitty food factory 🤣🤣
Rob123
Post by Rob123 on Dec 16, 2021 14:35:07 GMT 1
Not so ffwwwoooaaarrr 😂😂
Post by Mr Kipling on Dec 20, 2021 18:48:46 GMT 1
wow some great progress being made cant wait to see the finished exhausts....
Post by yamark on Dec 21, 2021 16:22:38 GMT 1
Absolutely awesome work Rob. The pipes look like you've been making them all your life. Following with interest Mark
Rob123
42l Build
Dec 21, 2021 17:09:11 GMT 1
via mobile
Post by Rob123 on Dec 21, 2021 17:09:11 GMT 1
Absolutely awesome work Rob. The pipes look like you've been making them all your life. Following with interest Mark Much appreciated Mark & Mr kipling 👍 I just hope they work well with the engine, I can't wait to get it finished now 😉
Rob123
Post by Rob123 on Dec 30, 2021 20:01:59 GMT 1
Post by sidney81 on Dec 30, 2021 21:24:49 GMT 1
Hi bud 👋 cool they look great especially as it's your first time with a Tig !! There not going to fall apart!! It's all about having ago . What's your gas set at ? You want about 8-10 ltr per min , as soon as you dip your tungsten ,sharpen it back up again rather than try carry on , good effort I say well done 😊👍
Post by evochris on Dec 30, 2021 21:45:10 GMT 1
Looks great, must be extremely satisfying making your own pipes, nice job👍
Rob123
Post by Rob123 on Dec 30, 2021 22:59:13 GMT 1
Hi Chris I had the gas set to around 10 mate 👍 Current was set at 40. Since doing the pipes I practiced abit more and turned it up to 60 and it seemed to flow the rod/weld easier I wish I'd of done them with it turned up abit now lol. Although starting off I had it on about 30 cause it kept burning a hole. Any minute gap and it would burn through what a pain 😂. I have definitely learned alot mate as you said any gap/lip caused me an issue. Next set I will get the cones alot tighter fit 👍. I must have dipped the tungstens about 50 times lol. It's hard getting my left and right hand to work in sync. I just need to stay calm and not start shaking 😂😂 Rob
Rob123
42l Build
Dec 30, 2021 23:08:44 GMT 1
via mobile
Post by Rob123 on Dec 30, 2021 23:08:44 GMT 1
Looks great, must be extremely satisfying making your own pipes, nice job👍 Cheers Chris it certainly is mate I can't wait to hear them now. I'd describe it like waiting to see your child for the first time 😄👍
