Post by Yogi on Sept 7, 2021 16:01:28 GMT 1
This looks lovely Yogi, is it a fe-fresh of the old 385 (same bodywork) or something new? Mouse Cheers mouse Original bodywork,clocks,seat and wheels,all the rest went on Waggers hybrid 👍 Cheers Matt 🐻
Post by Yogi on Sept 11, 2021 16:36:39 GMT 1
I bought this engine with a fresh rebore and pistons,the oil had been changed as well Still not taking chances so I opened it up Another one with the crank seal in backwards and the valves were worn on the inners But what I found in the sump was far worse, thank god I didn’t take a chance on it Matt 🐻
Post by mouse on Sept 11, 2021 18:12:57 GMT 1
Smarter than the average bear!
Good on ya Yogi, just shows that not everyone's idea of 'fresh' is quite the same! Glad you found it.
Mouse
Post by midlifecrisisrd on Sept 11, 2021 18:33:46 GMT 1
Yuck 😕
Worthwhile job then
Post by Yogi on Sept 12, 2021 17:31:11 GMT 1
Engines built and in 👍 Gearing up to tackle the ignitech 😬 Matt 🐻
Post by oldbritguy on Sept 12, 2021 18:14:57 GMT 1
Vape power Dynamo too! I have one to fit to my LC motor but not got round to it yet. Did you need to fettle anything to make it fit or was it straight forward enough. Also the rotor is not keyed so interested to see if timing it up is easy too. Watching intently 😉 John
Post by mickross355 on Sept 13, 2021 1:06:25 GMT 1
Matt Where did you get the side stand from? Cheers Mick
Post by Yogi on Sept 13, 2021 17:00:20 GMT 1
Vape power Dynamo too! I have one to fit to my LC motor but not got round to it yet. Did you need to fettle anything to make it fit or was it straight forward enough. Also the rotor is not keyed so interested to see if timing it up is easy too. Watching intently 😉 John No fettling mate it fits straight on Let you know how I get on with the timing 😬
Post by Yogi on Sept 13, 2021 17:01:01 GMT 1
Matt Where did you get the side stand from? Cheers Mick Triumph 595i or 955i 👍
Post by yamark on Sept 13, 2021 18:14:13 GMT 1
Super stuff as always Matt. Following with interest
Post by Tobyjugs on Sept 14, 2021 8:07:15 GMT 1
Wow that's quick.
What type of clutch cable have you fitted Matt?
Post by Yogi on Sept 14, 2021 9:09:58 GMT 1
Wow that's quick. What type of clutch cable have you fitted Matt? Hi mate It’s off a Ybr125 custom,there oem so good quality and there’s an adjuster in the middle too A little longer than standard though 👍
Post by Tobyjugs on Sept 14, 2021 9:16:59 GMT 1
Its a great idea.
Post by Yogi on Sept 27, 2021 17:31:26 GMT 1
Well the iggy is almost wired along with some other bits Timing wheel and Dti finally arrived as well 👍 Matt 🐻
Post by yamark on Sept 27, 2021 18:03:37 GMT 1
Matt, I don't know how you do it, but your bikes always look brand new. Fabulous work
Post by dusty350 on Sept 27, 2021 19:00:19 GMT 1
Looking great Matt - I do love white wheels Dusty
Post by arrdy350 on Sept 27, 2021 19:41:40 GMT 1
Excellent 😀 What make are the exhaust pipes?
Post by drc on Sept 27, 2021 22:32:41 GMT 1
Really nice. Cracking build.
Post by Yogi on Sept 28, 2021 16:57:40 GMT 1
Excellent 😀 What make are the exhaust pipes? . Cheers Chaps Arrdy350 I’ve been told there gibsons but not sure 🤔 There quite quiet but go well enough 👍 Matt 🐻
Post by Yogi on Oct 8, 2021 16:45:09 GMT 1
Well I took what I hoped was the easiest option after buying a Dti I welded a 2mm washer to a piece of flat bar and bolted it across the barrel Then after speaking to Dave(muttsnutts) lined the flywheel up with the trailing edge halfway across the lobe Last thing was to set the pick up gap at .40 Matt 🐻
Post by Yogi on Oct 9, 2021 16:09:17 GMT 1
She’s alive again on the 3rd kick 👌press on pic for video Arrows rebuilt oil pump bled up perfectly as usual Happy days 👍😂😂 Matt 🐻
Post by arrdy350 on Oct 9, 2021 16:14:12 GMT 1
Sounds great 😀👍
Post by muttsnuts on Oct 9, 2021 17:25:30 GMT 1
LOL - told it would all be ok, easy that wiring lark........ sounds good, just needs a dyno session now to get it spot on for your set up
Post by Yogi on Oct 9, 2021 17:37:43 GMT 1
LOL - told it would all be ok, easy that wiring lark........ sounds good, just needs a dyno session now to get it spot on for your set up Lol,it’s ok once you bite the bullet and get going I used the violet wire for the tacho and it works fine(doesn’t tick with the indicators on) 👍 I’ll have a word with Andy to drop it off when you’ve got time ( probably2023) 😂😂😂
Post by muttsnuts on Oct 9, 2021 19:38:31 GMT 1
LOL - told it would all be ok, easy that wiring lark........ sounds good, just needs a dyno session now to get it spot on for your set up Lol,it’s ok once you bite the bullet and get going I used the violet wire for the tacho and it works fine(doesn’t tick with the indicators on) 👍 I’ll have a word with Andy to drop it off when you’ve got time ( probably2023) 😂😂😂 so you've got a high voltage tacho then No problem, getting on top of jobs now, reckon by February I should be on an even keel and be able to book new jobs in, going to have 2 dedicated days a week for dyno work, so should be a reasonably short wait to get a bike dyno'd going forward, no more 6 month wait ! Might even get a chance to get back onto some of my own projects including the turbo one
Post by Tobyjugs on Oct 9, 2021 20:52:03 GMT 1
Nice one Matt
Post by Yogi on Oct 10, 2021 7:22:47 GMT 1
Lol,it’s ok once you bite the bullet and get going I used the violet wire for the tacho and it works fine(doesn’t tick with the indicators on) 👍 I’ll have a word with Andy to drop it off when you’ve got time ( probably2023) 😂😂😂 so you've got a high voltage tacho then No problem, getting on top of jobs now, reckon by February I should be on an even keel and be able to book new jobs in, going to have 2 dedicated days a week for dyno work, so should be a reasonably short wait to get a bike dyno'd going forward, no more 6 month wait ! Might even get a chance to get back onto some of my own projects including the turbo one Let me know nearer the time mate 👍
Post by abar121 on Oct 10, 2021 10:34:56 GMT 1
Great job Matt.
Love the sound too.
Post by yamark on Oct 10, 2021 18:59:12 GMT 1
Sounds very crisp Matt, great work
Post by Yogi on Oct 11, 2021 11:46:56 GMT 1
Cheers mates 👍😂
