Post by donkeychomp on Jul 29, 2021 21:32:04 GMT 1
For the little Mito. Means I've had her almost a year now and I've enjoyed every moment. Went over her earlier and I can't find anything amiss so she should pass ok. Wish me luck!
Post by dusty350 on Jul 29, 2021 21:33:35 GMT 1
Good luck mate. I'm sure she'll fly through Then it's fingers crossed for some decent weather again ! Dusty
Post by midlifecrisisrd on Jul 29, 2021 21:36:23 GMT 1
I'm sure it will be fine 👍
Post by donkeychomp on Jul 29, 2021 22:29:29 GMT 1
Cheers lads. Decent weather or not she's booked in! And I really don't like riding in the rain...
Post by JonW on Jul 30, 2021 1:13:27 GMT 1
wow a year already! Time flies...
You'll be fine Alex, you'd have fixed anything iffy as you ride the bike etc.
Post by Tobyjugs on Jul 30, 2021 11:03:04 GMT 1
Good luck Alex
Post by donkeychomp on Jul 30, 2021 19:52:31 GMT 1
Well...she failed and I got soaked. Headlight is a Euro spec one...can't afford a UK one so they did say they'll slap some tape on them for me. Seat is loose. Not a problem. And the rear shock and exhaust mounting bushes are shagged. Now that's kind of a problem as I can't find any. However there are universal ones I can use...trouble is I need to take the old bushes out to see what size they are and that is a bit tricky with a fully faired bike and no centre stand. I'm working this weekend but hoping to have a go at this (somehow!) on Monday.
Post by midlifecrisisrd on Jul 30, 2021 20:02:49 GMT 1
Bummer ☹
Post by dusty350 on Jul 30, 2021 20:24:48 GMT 1
Hi mate Can you whip the belly pan off and get that jack that's under the Lc at the mo, and jack up under the engine on the frame tubes ? Stick some axle stands under the Lc for the time being ( I have a pair of stands you can borrow if needed) Loosen off nuts and bolts before you jack it up Dusty
Post by abar121 on Jul 30, 2021 21:49:50 GMT 1
Abba stand is a good one unless you need to drop the swinger too.
Post by donkeychomp on Jul 30, 2021 21:53:09 GMT 1
There are no frame tubes mate! All I can think of is either laying the bike on it's side (not something I want to do) or use that chain system I have in the workshop/antique shop. But I reckon it's going to be a bugger to do.
Post by midlifecrisisrd on Jul 30, 2021 21:54:44 GMT 1
Abba stand is a good one unless you need to drop the swinger too. You get a swing arm removal kit for the abba stand 2 big bobbins that screw into the footpeg hanger mount bolts Stand locates onto them instead of the swing arm pivot Steve
Post by abar121 on Jul 30, 2021 21:56:34 GMT 1
Yep. I've got one. All the adapters and gubbins really add up! They do a trade kit, but even then..
Post by midlifecrisisrd on Jul 30, 2021 21:57:00 GMT 1
Is the front spindle hollow
Bit of rod through it then use a paddock stand
Then either Jack under the rear of the engine or tie the rear to the ceiling
Post by abar121 on Jul 30, 2021 22:17:31 GMT 1
Use axle stands under the foot rests. If they fold up, replace them with bolts.
Post by donkeychomp on Jul 30, 2021 22:34:59 GMT 1
Now that might work! I'll give it a go. Thanks for all the help lads.
Post by chrisg on Jul 30, 2021 23:09:41 GMT 1
Good luck mate. I'm sure she'll fly through Then it's fingers crossed for some decent weather again ! Dusty Think there is a heatwave forecast for mid Aug, so keep your fingers crossed 🤞
Post by donkeychomp on Aug 2, 2021 20:01:18 GMT 1
With my renewed mojo I had a go at the Mito today. First job was the exhaust bush. Luckily I had a spare that fitted so one job done. Then I made up a little bracket and the seat now bolts down. And after much swearing and effort I also loosened the rear shock bolt. That was a right bugger. Next up is axle stands to whip the dead bush out, and I'm hoping I have a new one kicking about, and then it's sort out the clutch cable routing.
