smoke
Post by smoke on Jun 20, 2021 19:52:19 GMT 1
Hi, I just bought an -84 RD350LC YPVS, 31k, in pieces, and got an extra engine with it. When I measure the bore sizes with a cheap digital gauge I get 63,85 on top and 64,01 at bottom for both cylinders. Should I assume this is due to the cheap gauge?
Regards, Smoke
Post by stirling11 on Jun 21, 2021 9:51:44 GMT 1
Standard bore is 64mm, if the measurements are what you say you have then you have some relatively unused barrels, which in itself is unusual and rare particularly for a 1984 bike
Post by midlifecrisisrd on Jun 21, 2021 17:59:42 GMT 1
Measuring with a vernier caliper at the top will always give a smaller reading as the rings don't travel to the top of the bore so it wears less
For an accurate measurement you would need to check the bore at different point to check taper and oval
Good news that it's on standard size, plenty of meat left
smoke
Post by smoke on Jun 21, 2021 18:23:02 GMT 1
Measuring with a vernier caliper at the top will always give a smaller reading as the rings don't travel to the top of the bore so it wears less For an accurate measurement you would need to check the bore at different point to check taper and oval Good news that it's on standard size, plenty of meat left Steve Thanks Steve! I'll try to find a better gauge for internal measurements. Probably there may be most wear around the ports. Plan on honing before rebore. Cheers!
