Post by muttsnuts on Jun 20, 2021 13:47:21 GMT 1
Anybody got a MK3 CDI unit they want to sell, or a known good one I could loan to prove beyond doubt that the one on a bike I am working on is fried, I am 99% certain it is, especially since its a known weak point, but the customer isn't convinced (odd stance but there you go)
Alternatively, does anybody know of a good alternative, I know I can get an ignitech unit and fit that, but just wondered if there was other options as 125's aren't my thing !
Thanks in advance
Post by crm on Jun 21, 2021 20:08:56 GMT 1
Dave - what are the symptoms ? i went through this on my Mk3 YPVS and it actually turned out to be really slow because of 1 - my extra weight since i last rode it. 2 - air gap on the pickup was huge. If you don't source one i will lend you mine to try
Post by muttsnuts on Jun 21, 2021 20:21:57 GMT 1
yeah, it starts ok, but after a few minutes, it coughs, splutters and then stops, won't restart for a good while, check no spark, then it statrts, then same again after a few minutes, its not the stator or low/high side coils etc, they are all fine, both cold and hot, pickup is also fine
Everything else checks out, its the only part I can't test and does smell of CDI issues like the 31K when that starts going, very similar symptoms
Post by crm on Jun 21, 2021 20:25:34 GMT 1
Dave, will dig the CDI off the bike this week when back at the lockup for you. It is a full power Mk3 working YPVS yes ?
Post by muttsnuts on Jun 21, 2021 20:32:03 GMT 1
yeah, UK full power YPVS, not got much power at the moment mind !
Post by crm on Jun 21, 2021 20:41:11 GMT 1
Dave - 1GU-MO with 66J on the bottom 1 x 5 pin block connector (Orange, green & White, red & white, brown, black) 1 x female bullet (black, white) 1 x male bullet (yellow) 1 x male bullet (red, black)
Post by muttsnuts on Jun 21, 2021 20:56:32 GMT 1
yup, exactly that
Post by guiri on Jun 22, 2021 18:31:05 GMT 1
Dave . the one off the first tzr125, 2rh does the job. dont bother putting another 1gm cdi on it as they are cac. Someome is also making new ones but cost a couple of hundred quid. a used tzr one should be less than 50 bucks and dont give trouble.
Post by muttsnuts on Jun 24, 2021 13:22:17 GMT 1
yep CDI knackered, big thanks to Paul for loaning me his to verify that
Post by muttsnuts on Jun 28, 2021 21:45:05 GMT 1
Dave . the one off the first tzr125, 2rh does the job. dont bother putting another 1gm cdi on it as they are cac. Someome is also making new ones but cost a couple of hundred quid. a used tzr one should be less than 50 bucks and dont give trouble. yeah got a 2RH one, but I think its buggered as I've no spark, I think the pickup wires need swapping round, but tried several thinga with no luck, so back to sqaure one with the damn thing !
