Post by noonster on Jun 20, 2021 13:46:07 GMT 1
Any body used these clutch kits on there rd350lc
May try one on my rd as well as the pro start mod
See if my neutral problem goes away
Post by dusty350 on Jun 20, 2021 13:52:43 GMT 1
Yep, that's what I used on my Lc, Pv and Ac rebuilds. Maintains the correct stack height for the clutch to operate correctly (not all aftermarket kits do !) I got mine from Dave (Mutts) Dusty
Post by muttsnuts on Jun 20, 2021 13:54:45 GMT 1
yes, only ones I use, I stock them as well, best replacement clutch kit as fibres and steels are the correct thicknesses, springs are 15% heavier and you can't use the damper rings as the frictions are wider, but other than that, they are a direct replacement, not had any issues and probably fitted/sold 100+ of them - plus they have handled 70+bhp no problem
