Post by noonster on Jun 19, 2021 13:53:33 GMT 1
whats the best way please to remove the star gear from the gear drum shaft on my lc350.
screw come out easy
fubars
Post by fubars on Jun 19, 2021 13:57:40 GMT 1
I did mine a few weeks ago seems like the Yam engine screws are made of chocolate.
I rounded mine off slightly so stopped with the screwdriver and used my tried and trusted impact driver came out easy after a couple of short hits.
Post by midlifecrisisrd on Jun 19, 2021 14:05:42 GMT 1
Yep, impact driver
I tend to leave them well alone
Post by noonster on Jun 19, 2021 15:33:40 GMT 1
ive got the screw out,its the gear thats tight to come off
fubars
Post by fubars on Jun 19, 2021 15:34:49 GMT 1
Just tap it with something it will come off.
Post by noonster on Jun 19, 2021 16:00:20 GMT 1
got it now thanks, next question please, its the neutral im having issuse with. i can feel it very sharpe on the stargear where netrual is. should i buy the pro star mod and use the original spring on the new detent arm, or use the lighter spring
or just use a dremel and take the sharpe ends off the neutral tooth,them put it back together
Post by 4l04ever on Jun 19, 2021 17:41:07 GMT 1
The star is usually not the cause of the neutral issues, but worth modifying while you have it out. I round of the peaks on the star and keep the standard spring. I also modify the stopper arm with a nice bearing.
You need to check that all your clutch plates are perfectly flat, or get a new set. DRC043 EBC kit works well. Wide plates, so no rubber rings required, but comes with metal plates, fibres and new springs.
