Post by mellow on Jun 14, 2021 20:40:23 GMT 1
When my 350 had the duff did on it would start and idle but give it throttle and nothing happened, still just idled 🤔 I know you have tried another cdi but worth checking rotor/stator/pick up as shows what timing can do Steve Yep I'm going to try without filter first, as sounds like air restriction, but who knows,then check spark and coil, then il check stator etc, although timing is essentially fixed on these👍 Thanks for the suggestions guys👍😎
Post by mellow on Jun 14, 2021 20:41:46 GMT 1
To be fair there's no slack on lower cable and about 3mm at twistgrip👍
Post by tony2stroke on Jun 14, 2021 21:02:04 GMT 1
1 more thing I would say is, check all the bits in the carb have the Mikuni logo, maybe someone used a shyster (keyster) or shambits carb kit, and they are no good.
