Post by shaunthe2nd on Jun 6, 2021 20:47:03 GMT 1
I've been building a 1983 31k and have a resto post on here, and need a bit of help.
I finally got to try start it today after many months of refurbishment. Tried kicking it and wouldn't start and seems I have no spark. Grrr.
-Full engine rebuild and carb clean etc. -I've fitted new NGK BR8ES resistor plugs (but tried a couple of other random plugs for a spark) -I've fitted NGK LZFH Non resistor plug caps -Checked resistance on alternator pick up (pulser) and checks ok -Checked the source coils resistance and checks ok -Tried 2 different ignition coils and neither result in a spark
My guess is a faulty CDI. Its fitted with a 29k-50 unit, which has signs that someone has tried to peel it open before. I also read on here that they are vulnerable.
Any other thoughts?
And the big ask.... does anyone have a working CDI they would be prepared to loan me for a few days to test if that's my problem?
many thanks, Shaun.
Post by muttsnuts on Jun 20, 2021 12:50:37 GMT 1
CDI is a known weak point on them Shaun, had several in over the last few months, all the same fault, replaced the CDI and all good in the world again
Post by shaunthe2nd on Jun 21, 2021 19:56:24 GMT 1
CDI is a known weak point on them Shaun, had several in over the last few months, all the same fault, replaced the CDI and all good in the world again Thanks Dave, proved to be the case. Bought a good one and engine is now running. Still got stuff to do to finish the build but seems to be heading in right direction.
