Post by midlifecrisisrd on May 19, 2023 20:37:48 GMT 1
Finally got the brake pedal welded up I've since shaped it a bit better then dropped it off for powder coating along with some other little parts I'd already had the tie bar brackets done so cleaned, stripped and painted the bars tonight ready for fitting Steve
Post by midlifecrisisrd on May 20, 2023 22:09:26 GMT 1
Fitted the tie bars tonight Hoping to drop the bodywork off for painting next week. Decided to make up blanks for the tap and cap so cut an old tap up and blocked up the holes then made up a disc on the lathe to make a cap blank Noticed a couple of small chips in the tank primer (was primed when I got it) so used a little 1k filler on them, I'll flatten tomorrow Steve
Post by yamark on May 21, 2023 15:53:28 GMT 1
Really enjoying this build Steve . You have an amazing skill set and eye for detail. I love your practical approach. I always learn something new from every build thread you do- awesome work Following with interest, Mark
Post by midlifecrisisrd on May 21, 2023 17:17:38 GMT 1
Very flattering Mark, thank you
Post by midlifecrisisrd on May 22, 2023 13:30:47 GMT 1
Just dropped the body work off along with half a litre of competition yellow solvent base coat
Says he will paint it and give it a coat of clear. Tank will be flattened for me to fit the decals (not looking forward to KR tank decals) before more clear coat
Sides and tail are laminated so not getting over coated
Also said he was really busy so only time will tell when I get them back
Post by midlifecrisisrd on May 23, 2023 10:36:53 GMT 1
Painter called, had a cancellation, bodywork is done 😳
Post by JonW on May 23, 2023 14:16:20 GMT 1
wow, that was fast!
Post by midlifecrisisrd on May 23, 2023 16:58:10 GMT 1
Think it's a new record for him lol He must have piled up the bodywork, poured the pain over it and let it run down over it 🤣 Steve
Post by sidney81 on May 23, 2023 20:26:04 GMT 1
Great 👍
Post by oldbritguy on May 23, 2023 20:39:03 GMT 1
That was proper quick Steve Looking forward to see what a 24hr paint job looks like. Hopefully no curtains or royal icing 😉 John
Post by midlifecrisisrd on May 24, 2023 10:30:26 GMT 1
Paintwork collected Needs flattened and a bit dusty but it's deffo yellow 🤣 Was a little nervous as the paint was from ebay so no idea on quality No front muddy as I have a carbon dipped one to use Steve
Post by tdrpete on May 24, 2023 11:00:48 GMT 1
They call me mellow yellow repeat to fade. Looks the bee knees.
Post by JonW on May 25, 2023 0:35:21 GMT 1
Irn Bru at the ready I see... Good lad!
Post by midlifecrisisrd on May 26, 2023 20:42:29 GMT 1
Been a busy boy tonight Flattened the tank back ready for decals then painted the bottom of the side panels satin black Then I took the handlebars off and milled 30mm off them as they were too wide I'd had the switchgear and rear caliper bracket blasted through the week so painted them all satin black Steve
Post by midlifecrisisrd on May 27, 2023 11:58:26 GMT 1
Big boy pants on this morning ready for the tank decals Dear God they are difficult but thank God there is a guide on the image works site You have to fit them a specific way to stop a crease or having to make a cut going into the knee dent They are fitted with the application tape off each stage and it's a bit scary using a heat gun on a decal. You can see it shrivelling as you heat it up to manipulate it First one done, wish me luck for the second 🙏 Steve
Post by headcoats on May 27, 2023 12:22:27 GMT 1
Wish you luck for the second !
Post by midlifecrisisrd on May 27, 2023 12:35:18 GMT 1
Half way 😬
Post by midlifecrisisrd on May 27, 2023 12:57:09 GMT 1
And done 😰 That's taken over 2 hours to mark up then do Steve
Post by jessy03 on May 27, 2023 13:44:43 GMT 1
Pukka job there Steve, I’ll be sending you my bodywork from now on 👍👍
Post by midlifecrisisrd on May 27, 2023 14:54:09 GMT 1
Went to do the next job, paint the calipers All masked up and got out the can of specially made pearl gold pearl gloss caliper paint Luckily I tested it an a piece of paper fist cause it ain't feckin gold 😭
Post by midlifecrisisrd on May 27, 2023 15:55:25 GMT 1
And tail panel fitted with laminated decal Steve
Post by midlifecrisisrd on May 27, 2023 18:40:03 GMT 1
Next was on to the front indicator stems Headlight brackets had a 12mm hole but the stems are 14mm with 2 flats so the indicator can only go in the correct position First i marked a horizontal line on them using a spirit level then clamped them onto the mill and elongated the holes 1.1mm in each direction and all sorted Steve
Post by dusty350 on May 27, 2023 20:46:00 GMT 1
Great work Steve And well done with the decals. Did 2 stripe blue decals some years back - never again
Post by donkeychomp on May 27, 2023 21:24:28 GMT 1
I concur. Decals are a bugger to do and I'm impressed with your use of a heat gun!
Post by midlifecrisisrd on May 27, 2023 21:38:37 GMT 1
Cheers guys
I started with a heatgun on a low setting but soon moved on to the wife's hairdryer as I could get it hot with a low fan speed 🤣
On the Image Work site it says standard LC decals are 8/10 for difficulty and speed block is 11/10 😖
Glad they are done, I've been dreading doing them since I bought the kit last October
Post by midlifecrisisrd on May 27, 2023 22:40:29 GMT 1
Baked the switchgear in the oven (can you tell the wife is away 😆) then fitted decals Steve
Post by donkeychomp on May 27, 2023 23:06:45 GMT 1
Perfect.
Post by midlifecrisisrd on May 28, 2023 12:42:09 GMT 1
Went back to plan A on the brake calipers Paint was actually the B option but that didn't work out Plan A was to ceramic coat them (Cerakote) so out came the compressor, the Cerakote gun, a respirator and a steep learning curve Used C series Glacier Gold so air dry but think it takes about a week to fully cure Looks good but only time will tell how it is when it is dry Steve
Post by mouse on May 28, 2023 17:41:55 GMT 1
A whole new set of skills there Steve, i'm very impressed!
Mouse
Post by midlifecrisisrd on May 28, 2023 19:08:23 GMT 1
Well I'll see what it's like when cured lol
Checked up and its dry in 24 hours but 5 days to fully cure
It's actually satin but hadn't dried off yet in the pic
I'd never even used a spray gun before 🤣
