Post by woolly69 on May 23, 2021 7:26:09 GMT 1
I'm after the size of the ball bearing in the clutch as want to up grade to ceramic
Post by reedpete on May 23, 2021 20:53:28 GMT 1
5/16
Not sure quite what type of ‘upgrade’ you are expecting.....steel or ceramic will make zit difference..
Do You have something you are not happy with that you are trying to improve?
Post by Norbo on May 24, 2021 22:58:42 GMT 1
They are the same as an lc bearing but normaly ceramic ones are only fitted to hi power bikes 421 85 bhp and above no real point if its a normal or tuned road bike . Mined you ther cheep and they are better then steel ones any way so i see no problem with the upgrade
