Post by 17again on May 12, 2021 19:20:50 GMT 1
Post by 17again on May 12, 2021 19:21:59 GMT 1
here is my doner bike which i had to strip pretty quick so i didn't change my mind and keep it. its been down the the road and it's a right off N repairable. i wanted it because the motor had done 23000 miles now some panels are off and sold their is no going back i plan to use all the parts i want front + rear end and engine and sell the rest off.
Post by 17again on May 12, 2021 19:22:41 GMT 1
got some more of the donor bike apart today next its the fz
Post by 17again on May 12, 2021 19:23:20 GMT 1
Post by 17again on May 12, 2021 19:23:49 GMT 1
stem pressed out and fitted
Post by 17again on May 12, 2021 19:24:23 GMT 1
managed to dry fit some of the ace bits today. forks had to grind off a bit the steering lock so the forks could move right over to the left. i put the clip ons as test on top of the yokes but still not sure about these. engine its just chucked in via 2 bolts went in ok. exhaust not sure what to do here just yet weather to try and fit a aftermarket one like a black widow (thunderace) it might give a bit more clearance. as it hits the centre stand bracket easy to cut off i know, thinking more about the footpegs bolts
Post by 17again on May 12, 2021 19:25:16 GMT 1
managed to get the old swing arm oi today without my abba stand swingarm removal kit as they are not instock. got some top hat sleeves from steve at lucky 7 motos managed to smash the old needle bearings out with lots of heat from my hot gun 2x TA2525Z next i have to find someone to machine the arm and centre spacer down 5 mm per side.
Post by 17again on May 12, 2021 19:25:58 GMT 1
got a little bit done today. got the swingarm back which for me i had 5mm machined off each side + the spindle 5mm by using the top hat supplied by luckymoto7 the top hats add 3mm using this method i was able to use the dust caps on the end of the bearings still. fitted the new needles from bolton bearings next ground off the centre stand brackets so the linkage would fit the arm fitted perfectly and next i need to find a fzr 1000 exup shock as recommended David Houghton + sort out the linkage the ace arm is a shorter see photo below but i think it will be fine as from the centre of the bolts its only 15mm shorter.
Post by 17again on May 12, 2021 19:26:36 GMT 1
done a bit more to the linkage today. added the spacers at the bottom of the frame i also had to change bush to fit the 12mm bolt which i just had one cut down from a rgv25o i had kicking around. added some top hats spacers to reduce the frame + added top bolt to a 10mm so far all pretty much the thunderace linkage.
Post by 17again on May 12, 2021 19:27:13 GMT 1
frame is back from the powder coaters now. now the rebuild begins
Post by 17again on May 12, 2021 19:27:40 GMT 1
Post by 17again on May 12, 2021 19:28:08 GMT 1
Post by 17again on May 12, 2021 19:28:35 GMT 1
Post by 17again on May 12, 2021 19:39:38 GMT 1
Post by veg on May 12, 2021 20:58:49 GMT 1
Fan bloody tastic. 👍
Post by JonW on May 13, 2021 4:50:49 GMT 1
Wow, what a fantastic build. Love this!
I assume the idea here is to get a faster FZ750 that handles and stops better and is a smaller bike? Im thinking that as the Thunderace frame is a more modern design and is probably stronger but is a big bike so the FZ while floppier is more fun?
Post by 17again on May 13, 2021 16:35:27 GMT 1
thanks for the compliments guys.
smaller but heavier lol
yes i love the old bikes but would like the better handling as some of us do.
should go well to : )
Post by 17again on May 28, 2021 18:14:35 GMT 1
Post by donkeychomp on May 28, 2021 21:15:47 GMT 1
Brilliant! The rear end looks fine to me, but like you say that exhaust needs elevating a bit.
Post by markhoopy on May 28, 2021 21:58:03 GMT 1
Do you think the rear end is to high? The rear looks fine to me but I think the front is too low. If the plan is to have the fairing on it I'd get it loosely fitted for a better idea. Are you racing with Yogi for 'fastest build of the year' by any chance?
Post by drc on May 28, 2021 22:39:32 GMT 1
Cracking Job !!!
I love the FZ750. I had an 86 and it was one of the bikes that I always regretted selling.
Good luck with the build. I'll be following with interest
Post by mouse on May 29, 2021 6:44:48 GMT 1
I don't think the rear looks too high at all, bike looks just right. But please stop posting pics, i'm so envious!
Mouse
Post by 17again on May 29, 2021 7:38:38 GMT 1
Do you think the rear end is to high? The rear looks fine to me but I think the front is too low. If the plan is to have the fairing on it I'd get it loosely fitted for a better idea. Are you racing with Yogi for 'fastest build of the year' by any chance? lol no i started this one in october 2020, i just reposted here
Post by 17again on Jun 26, 2021 13:28:30 GMT 1
Post by 17again on Jul 18, 2021 10:37:02 GMT 1
matt7
Post by matt7 on Jul 18, 2021 21:27:47 GMT 1
Fork extenders & above yoke clipons don't look safe. Good looking bike bar that
Post by mouse on Jul 18, 2021 21:32:49 GMT 1
Looks terrific Max, good luck with the MOT and let us know how she rides!
Mouse
Post by 17again on Jul 19, 2021 8:34:19 GMT 1
Looks terrific Max, good luck with the MOT and let us know how she rides! Mouse thanks mouse, will do! how you getting on with yours?
Post by mouse on Jul 19, 2021 15:05:24 GMT 1
Looks terrific Max, good luck with the MOT and let us know how she rides! Mouse thanks mouse, will do! how you getting on with yours? Er not so good, she rides really well, only problem is she overheats and chucks coolant out everytime i have ridden her!!! Hope to get her sorted soon Mouse
Post by julianboolean on Jul 19, 2021 15:17:19 GMT 1
Sounds like the head gasket is blowing, which isn't good, hopefully it will just be a stuck thermostat, or similar
